Help! Leaking Shut Off Valve. - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-01-2010, 08:30 PM   #1
help! leaking shut off valve.
i have a bad shut off valve that will not cut the water supply to a toilet off. i want to replace the valve but the supply line coming through the floor is a plastic flexible tube instead of copper.
the valve looks like its held in with some metal ring crimped on it to hold it, instead of a pressure fitting and nut. i never replaced one with these plastic tubes so im kinda lost on what to do. if it was copper i can do it no problem BUT this is the first time i have seen this so. NEED HELP!
LOST x913x is offline   Reply With Quote
Old 03-01-2010, 10:11 PM   #2
Rewards Points: 18
Is the plastic flexible tube about the same diameter as a 1/2 inch copper pipe?It could be PEX.Easy to work with but you need some special tools.
daveb1 is offline   Reply With Quote
Old 03-01-2010, 10:26 PM   #3
thanks for the reply! yeah its about the same but i dont think its PEX, this stuff is almost clear and the PEX stuff i seen at the hardware store is white. could be wrong though. would you have a list of tools needed for this?
Old 03-01-2010, 10:44 PM   #4
Can you post a picture of it?
meboatermike is offline   Reply With Quote
Old 03-01-2010, 11:45 PM   #5
i would but my wife is out of town with the camera so i have no way of taking a pitcure.
Old 03-02-2010, 08:17 AM   #6
Rewards Points: 352
A plumbing supply house should have the new valve with a supply line already attached, you will still need to get the tool and ring to attach it after you cut the old one off
plumberinlaw is offline   Reply With Quote
How to diagnose gas valve problems Nestor_Kelebay How To Guides 28 10-30-2013 05:19 PM
New Compression Shut Off Valve for Toilet Leaking C_J_GO Plumbing 6 10-22-2009 04:30 PM
Shut Off Valve won't shut off DIY_Dumbie Plumbing 1 07-11-2009 03:22 PM
Best 1/2 inch water shut off valve. Nestor_Kelebay Plumbing 10 07-25-2008 12:16 PM
new install shut off valve leaking ferris84 Plumbing 3 11-12-2007 04:47 PM
