Help With Leaking Pvc Water Line - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-16-2009, 01:20 PM   #1
help with leaking pvc water line
We developed a leak in our pvc water line. My husband has tried to repair it following all instructions he has read, plus he has done this type of repair before. This time though despite letting the glue set for longer than usual(the last time for almost 24 hours) when the main valve is turned back on the joint blows out. Any ideas? We are really in a major bind.
sharoncita is offline   Reply With Quote
Old 08-16-2009, 03:05 PM   #2
GC/Master Plumber/Mech
Rewards Points: 560
A couple things
Are you getting the joints clean and dry?
How old is the glue?
There is a product called Rain N Shine works well if moisture is an issue.
John Wayne once said "Life is tough and it is even tougher if you are stupid"
Tempstar and Trane Dealer
Old 08-16-2009, 06:54 PM   #3
Master Plumber Lon
Send a message via Yahoo to lonsplumbing
glue water lines
You want to use cpvc cement for drinking water lines not rain or shine or pvc glue. Thats if your lines are cpvc like they should be.
You cant drink the water in all pvc pipes.
lonsplumbing is offline   Reply With Quote
water line joint leak dtzulu Plumbing 4 05-14-2009 09:18 PM
How to Install a Water Line to a Refrigerator With No sink yerac2003 Plumbing 6 05-07-2009 03:27 PM
Testing 12 year old hot water expansion tank? DJfixer Plumbing 2 01-01-2009 08:09 AM
Water leaking into septic pipe below toilet Gramps Plumbing 1 09-14-2008 09:54 PM
No water coming from main water line in bathroom sassylaroo Plumbing 6 10-29-2007 05:34 AM
