Help With Laundry Room Rough In - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-17-2011, 09:23 PM   #1
Help with Laundry room rough in
I have a six foot wall that I am putting a Stackable washer and dryer and a 3' cabinet with utility sink. I have access to 3" main drain from the second floor. I have included a drawing that I think is correct but any comments would be great.
TIA
spacecasenc is offline   Reply With Quote
Old 04-17-2011, 09:40 PM   #2
Plumber
TheEplumber's Avatar
Rewards Points: 792
Put the sink tee above or below the 2" washing machine tee. This will save you a 3x2 tee. Now you need to find a way to vent the washer/sink wet vent. You can't use a multi-story waste stack for venting. Perhaps a studer vent if allowed in your area.
Old 04-17-2011, 11:07 PM   #3
I think that the laundry box looks a little high. Are going to stack the washer on top of the dryer?
VIPlumber is offline   Reply With Quote
Old 04-18-2011, 09:27 PM   #4
Ok so would this be a better plan to follow? The existing washer in the room directly benind this new room has a studer vent so I asume that I can "move" it to the new location. I also moved the sink to the new vent line. And yes the washer box is high but I am trying to keep all the connections hidden behind the stackable washer and dryer. The dryer is on the top but the vent and dryer box takes up all my space a the normal level. The washer says not to put the drain over 96" and I am at around 72"
How high does the studer vent need to be?
let me know what you think.
Old 04-18-2011, 09:45 PM   #5
Thanks how about this layout?
Old 04-18-2011, 10:08 PM   #6
Plumber
Rewards Points: 792
Looks good. Studers need to be accessible for service if needed- height is OK
Invest in some nail plates for the studs- keeps the drywall screws out of the pipes.
Old 04-19-2011, 09:12 AM   #7
Ok, thanks for all the help. I do have one last question, what kind of T should I use to connect the vent pipe to the washer drain?
Thanks,
Old 04-19-2011, 11:19 AM   #8
Rewards Points: 131
Washers are usually on the bottom due to the weight on stack units. Why will the dryer be on the bottom? Maybe I am missing something.
HitLines is offline   Reply With Quote
Old 04-19-2011, 07:17 PM   #9
Plumber
Rewards Points: 792
Thanks,
When running drain lines, you want to use a 2" combination wye and 45 when you go vertical to horizontal, not a tee. But you need a tee for the laundry sink. The vent above the sink can be 1.5"
The Following User Says Thank You to TheEplumber For This Useful Post:
spacecasenc (04-19-2011)
Old 04-21-2011, 10:42 AM   #10
Rewards Points: 320
I believe there is a max distance for your washer drain to the trap which that looks to exceed. I forgot the exact number that the code lists.
autx790 is offline   Reply With Quote
Tags
laundry , plumbing , rough in , venting
laundry room wiring brit in canada Electrical 3 01-07-2011 09:45 PM
Well Room (Cold Room) Issue--Advice Needed TomPgh Building & Construction 11 01-03-2011 06:31 PM
Renovating the Laundry Room in 7 days newbsauce Project Showcase 4 10-12-2009 11:43 AM
occasional sewer gas smell in laundry room nebben Plumbing 3 03-25-2007 10:35 AM
Supply and Return from Laundry Room bjstewa HVAC 7 03-02-2007 11:39 PM
