Help With Kitchen Sink! Not Draining, Garburator Blows Water Up 2nd Sink - Plumbing - DIY Home Improvement | DIYChatroom
Old 06-23-2011, 11:56 AM   #1
Help with Kitchen sink! not draining, garburator blows water up 2nd sink
I've attached a picture, we installed the new sink as part of a kitchen reno, new cupboards mostly. It drained fine but occasionally when i ran the garburator water and bits of food would blow up the second sink.
last night the sinks stopped draining altogether, i pulled off the whole bottom part from the garuburator, sink and cross pipe at the flexible connector and nothing was plugged, i blew into the cross pipe and it didn't seem blocked.
Any thoughts on what this could be? I'm assuming that the water is not draining into the stack which is about 9 inches to the right of was you can see in this picture. this is the only thing that goes into the stack so i can test it at another sink etc...
any thoughts?
Help with Kitchen sink! not draining, garburator blows water up 2nd sink-plumbing.jpg
aldous314 is offline   Reply With Quote
Old 06-23-2011, 05:13 PM   #2
Rewards Points: 1,596
If it is not blocked under the sink, the block must be after the sink piping and in the downstream section of the drain line. Have you snaked this line? Is the drain line vented properly?
bob22 is online now   Reply With Quote
Old 06-23-2011, 09:48 PM   #3
take the no hub band off right where it goes in the cabinet wall. get a water hose and an old towel. get a bucket or something to hold water and put under what you are about to do. put the hose a few inches in the drain. wrap the towel in the space between hose and drain to form as good of a seal as you can. get the wife or a friend to turn the water on for five seconds and then turn it off. it will either blow out the problem or back up in the vent stack where the bucket will come in handy when you remove your towel. if it fixes it, good. if the water blows back on you and in the bucket at least you now know where your problem is. thanks, budro
i'm smarter than i look
buddy builder is offline   Reply With Quote
Old 06-24-2011, 08:06 AM   #4
well i did some more testing last night, it is a problem downstream of the stuff in the picture, i found an access cleanout thing in the basement directly below this sink, snaked it 25 feet, (was a plug at about a foot and a half)... and it still didn't clear,
i think the pipes in the basement are in bad shape, seemed like there was crud all along, i think i need to hire someone to look at it
Old 06-24-2011, 09:17 AM   #5
At least you know your work was fine.
Old 06-25-2011, 06:49 AM   #6
I wouldn't go that far. It may not be the problem now (this time), but the excessive pitch makes any vent pipe downstream useless, and Fernco couplings are not a good choice in any long term installation that could've just as easily been glued.
Ishmael is offline   Reply With Quote
Old 06-25-2011, 07:18 AM   #7
DIY staff
Rewards Points: 7,174
A P-trap for each sink is required in my area----
Also dish washer line is not allowed to drain into garbage disposal here--
Local codes vary--you are probably fine---Mike---
Old 06-25-2011, 08:56 AM   #8
A Little Of Everything
Rewards Points: 1,364
Before paying somebody $125 per hour to auger your drains, go buy one of these drain cleaning bladders. I've got 2 different sizes, and cannot begin to count how many times I've used them to blow out plugged drains.
It may not work for you, but you're sure not out much to try.
[IMG]http://www.diychatroom.com/data:image/jpg;base64,/9j/4AAQSkZJRgABAQAAAQABAAD/2wCEAAkGBhQREBAUExMVFRUVFBQQGBYQEhQVExgUFRAVFxQWGB cXHCYfFxklGhQVHy8gJCcpLCwsFR4xNTAqNScrLCkBCQoKDgwO Fw8PFykcHiApLCkpKSk1KSksKSksKSkpKSksKSkpKSksKSkpLC wpNSk0LCkpKSwsNSkpKSkpKSksKf/AABEIAOEA4QMBIgACEQEDEQH/xAAcAAEAAQUBAQAAAAAAAAAAAAAABAIDBQYHAQj/xAA+EAABAwICBwUFBwMDBQAAAAABAAIDBBEhMQUGEkFRYXEHEy KBkTKhscHwFEJSYnLR4SMzsmOCoiVDg5Lx/8QAGQEBAQADAQAAAAAAAAAAAAAAAAECAwQF/8QAHxEBAQEBAAIDAQEBAAAAAAAAAAECEQMSBCFBMWET/9oADAMBAAIRAxEAPwDuKIiAiIgIiICIiAiIgIiICIiAiIgIiIC IiAiIgIiICIiAiIgIiICIiAiIgIiICIiAiIgIiICIiAiIgIiIC IiAipklDQS4gAZkkAepWFqdd6KM2dVRX/K/a/xugziLAwa90LzZtVFf8ztn/KyzNPUtkbtMc1w4scHD1CC6iIgIiICIiAiIgIiICIiAiIgIiIC IiAiIgIiICKxWVrIWOfI9rGNxLnuDWjzK5xrZ2xwNjcyjftSnw 949pEbRvc0HFzuFxbfjkQ3jTetVNRi88rWE4hubz0aMbc8lo2l +26EAinZc/imcABz2WbRPmQuT1lS2Rxe+TvHuN3OleSSfNQZRvGXKxHqFeDY dOa3zVTiZJtvgNuzR0abAei16epdfh1VhzfNWXOLcsuBxCov/AGhStH6enp37UMr43DexxHrx81jsHjDA8Dv6H5FUtJGHxQdj1N 7brlsdc3l3zBa362Ddzb6LrlNUtkY17HBzXDaDmkFpByIIzXyT Twly3vULXeTRsgZJd9M8+JuZYT99nPiN/VSwfQCK3T1DZGNewhzXAOa4G4LSLgjlZXFAREQEREBERAREQER EBERAREQERY/Sun4KUAzSsZfIOPiPRoxPogn3Wsad7SKKkJa6YPeMNiLxG/An2QfNaDr3r86rcYaeTuoB7TmvDZZcLEYkFrMcjnv4DntTTbN7 Mw/F7XvV4MzrNrW7SEpfNM3Zv4IQ8iNg3fqdxOF1r00WGAFuLbEe5 WHAFW9gjFp9DiqPHNVBaRiDY8lV9o3OHmMD57iqj6jiPhyKotC f8WB4jLzHzCqcDl8MiqnRXVrFmfs/A8VBX9kwRj7us/Pj9ZqdTxbTbjFX5dD7bODhkfrcqJej6AEArJfZWltiLrCav6QI Lon4FuV/f9c1mX1FkRvvZPrGWOdQyOwsZISfV8fxcP8Acuor5rbpUxTQzM PjjeHjqDl0OXmvo2hqxLFHI32XsbIOjmgj4rGqvoiKAiIgIiIC IiAiIgIiICollDQS4gAYkuNgOpOSxOs+s0VDCXvu5x8LI2kbT3 WyF8hvJOAC4TrPrFU1hLqibC92wxG0beGWZ54lB1HXXtFbHGY6 R7XyuBBkb4mRjjcA7T+AHU7lxfTMj3uL5HvkeTculJx9VjJHcj 5kqkTuGTiPM2WXBQ6/BGyFuRIPLBV/ab+0PNuB9MivHR3xBuOI+Y3Kjw1Fz4seYwd/KrLcLg3HH9+Csli9bduI/wDoUFexfNUPYW4t8xuKvRWdl6c1Lig4qiLTOD8vQ5qbDRbVwcl BrKYxHvGjDes/RSNexrxv9xQYenJpZgHew7C/L9wtmFt3BYrTVJ3kR/EPEOo3KPoLSu1FsuOLMPLd81BG0+wxSsmbxsev8i4UiWvuARkQ CFZ0vP3jXN5e8YhYuinvHbgbeuKDICoO0Md6+iey+s7zRkHFhf F5Nebe4hfNbHYr6F7HB/03rNJ/ixSjekRFj0ERFQREQEREBEUDTGnIqVm3K8NG4ZucRuA3oJNXVs iY+SRwaxgLnOcbAAZkrjetnahUzlzaa8EFyA83bK8ceLQeAt1T XDtBfVju2t2YgQdk4kkZF3HjbpwWj19QXC+9WQRamskcSXSuJO/f65qN9pfvdtfqAKpKbKyAzA5jZ5jEemforb226HeMQVXsqkMLc sjmNxQUOarYBBu3D4eakWBFx5jgvWsQW43B2WB3j63K82G6tPp jmMwpmjpg/qPWygsT0Tmjab5gLI6MeJG33jPnzU9keCwdQTTVAcPYdjyt94f NBnJIA5paciLLA6KmME74XHAnD5HzC2AyDMHC1wtY1hd42PGYw v7wqM3V1u4LWo393ORud88R71LmqdoA8QCsZVP8bT9YFQTZJrq HR5uH1g7+VILc/NWKRvid5/5BQTYG4hfTPZ1o4waNpWkWLmmU/wDkcXD/AIlq4bqFqw6tq4o7eAf1JDwjBx8zkOZX0qxgAAAsBgAMrBQVIi ICIiAiIgIiIIOmdLMpYXyyHwtF8MydzRzK4TprWCStqC+Q2ucG 7mt+60chfzNzvWzdrusO3KKdp8MYBdbe9wHwBHqVzQ1my66yg2 0UsdgNkbuqxWk6doyWMfptx3qNNpAnMrLouOpbnBeS01gozKog qYKkEZqCAWqoBXHuCougsysIxbn8VJonB/XNUll1ZlYYiHjj7+KDNRUo4LFaSiMMjZGjC9iOf8rMUU4c0EZH 6sqqynD2OaciLdDuPrZQIagFrXDI4/uFD1haHwm2bTtDyz9yxei6stD4zuufMGxV6WswQW6Cu2orE+yb eW5RNIzbTCPP0KjUhsXjr7j+yuTjwu6FBTTuu1vmPf8AyrVUMW +fyV6iF2efyCpnbeRgU6JLsL9FK1V0NJUyBkTC97zYAepJO4DC 5OStQ0UlTNHTwNL5JHBoDfmdwAxJ3AEr6Z1I1Kh0bTMjYAZC0d 5LbxPdmejb5N+dyoGpGpzNH0+wLOlfZ0jxvduaPyC5t1JzK2NE QEREBERAREQF444L1Wa3+3JbPYd/iUHzbrBXmaaaQn23uf6uJWFJzUqscosdOTmQBnc87qinBeOapM +iyG7THseN+ybkeRxUJr+Ko9DOK8nicwXGSuObgpVJIC0td70G FNcVJpKgXxyUOvjs42UaOUgoNq2QrcrA4EHJQqWqu3orj51RTo irMb3Ru44dR+4Umoribi+Cw9bJZ7XD6IV2SW5Pr6qCO+TZmvxx PwKuucotT7TfMKY1v7oIkA/qH6+6pFULNPRW4ReU8v2VdRG6R7I2NLnuIAawFziTkABiSeCgU nhjueZWyaj9m9VpTbljLIog7Y72XaOO/YaB4yMN4HNbFqh2KVFSWPrQaeAWPdXHfycjb+2OuPLeu70Gj44 ImRRMayNjQ1rWiwAG5Qa5qP2c02i2kxgyTOFnzSAbZH4WjJjb7 hwxJW1oiAiIgIiICIiAiJdAXjgo1VpSOP23gedz6Ba7pbXVg8M RF/xOw9Ad/wBWWvXkzn+1lM2tD0V2ZtfLIaqQRsD3Ma24DnAPIBJ3A2wA9y2 DSHZTHsf0tlwtvuD5OuVi6iodK+wu5xOZ/lZ/QkcsWbjY5tJww+BXn7+R2tvo5hrF2fzU7i4McAMbHHDi1wz6Z9 Vrj3Rk+LC+ZG4/jHnmu76waziOMse0kEACXINLh4SRv6hcm7QtUwyCOuhdtMkOxK APYeRg7Dc438yOK6PD8jt9aw1j9az3uw4sdmMiMiOKubYsVg21 JIAObcum8KXFPguyNa3XZqASp1QbqG5iolUUllOc9YuHBTGm4V FmqOXUK9GMB0t6FW6hvhP1vV6mHhHmoI9Y3FvVTXO2W35fJRJv FIBuGJW06o6hVGlpB3YMdMD453Dwni1g++7pgN5CgwWgND1FS8 tp4XzSOOUbbhoO97j4WDqQu6dmXZONHn7TUlslU4YbOLIgRiGn 7z7YF3kN5O8aB0DFR08cELdljBYcSd7nHe4nElZFB5ZeoiAiIg IiICIiAvF6tZ1x1iNO3YaQHEFxJ+63H9iegKw3uYnauZbeRla3 TTGXDfE7gASAeZyHRa9VV5cSZdsj8rgGj/ba3qua13atLTytAYHsub4uY/ANyLcMyRYg5LctXNaodINPdmzwLuY6wkHMtGDm/mb5gLj3vWp38b5mS8ZB9O1+LCPTEdWnP3qI7VuOYnaOwcjsnwG ++x9nrlyCyFNOyKQhzbH4fwVarjjtswAzHD+D7vRc95WziLo7R 0lPK5hAkiFjc+3Hc2xvu5XyxWwRUu1vwyP7LF0lb3EkRcdqGf8 AptLs45w02jd+V7bgcHADIi1+t0j3RsCS0gEfpIOyT0sWnoFqu efad/ETXLRrH0rw322tJHMD2m+g9wXKaKrkdBUUjidh42bHHG/hPW9lv9ZWvkdhgM7nf5cOaxraONjXu2QMCSQeHNZTXE44gIS15 acwSD1BsVKhyXtZZ08paAG7byAMrFxsAvWhezPuOUcFaIV1ytq jxrVKiarDQpsbbBURazJXDIGMbxOQ3klZfVHVOXSlWIosGN8Uk hF2sbxPEm1gN/S5HedU+ymjoHCQNM04x72exLT+RoGyzyx5qDSOyzshDmmp0hED tgGOCUHK4O3I3ywYeZIyXZoYAxoa0BrQLANAAAGQAGACuWRARE QEREBERAREQEREBcr7UQe9lHGGS3lB/Dl1RaP2laPOzFOBcMdZ4H4Mdr/i6T3Ln+RO4bfFeafPencXbX5j/wA2hw+forGgtKupqyGYEjYe03abHZyPuOS2LTGhCxz4nH2T3W1 usfFTy/pINr8HLUainIvcEOaS1wOYINip4bNY9V8k5rr6C0Xpf7ZG7aAb NF4ZG/hNr3HFjhiOHkb5WnqQYSHYEYX5ZA+RwPyXJNT9eW7VMyVwjkja Ye9Psyw28MclvvNPsu4YHBdBiqtsEDp5EeHrw8vI8Pkx***l7F 6uIlppIxgHC4O9r2G4cObXAHq0Zb4bqp5ZH3hF77J34uZtOHTa ZcdTxUmiZYOvkfF7rfL6xUnQWgxVyEOJEcZBcW4XdYhrb7sCSf 5U9LuzMY2yfbCVFSSHbDSQ0Xc4AlrRa5LiMvNabrRrcCzuoMbi zn5Do3j1X0ZR0LImBkbQ1o3N+J4nmVoeuPY5T1ZdJTkU8puSAL wuPNo9g82+hXbj42c8t+2i+S188BllUts032Z19KTtU73tH36c d623Hw+IeYC1t9C8GxjeDwLHA+ll1taMvAFmKDVSsn/tUk7+YieG/wDsQAPVbfobsRr5bGXu4G/6jw99v0x3Hq4INF0do98r2sY0ue4hrWtF3EnIALo2huw+rnI+0 vbTxb2sIkncOAt4Gdbnouk6l9nFPo7xNJkmIsZXgCw3hjR7AO/Ek8dy25BitXNWoKCBsNPGGNGJ3uc62Lnuzc76FgsqiICIiAiIg IiICIiAiIgIiICsVlKJGOY7Jwt+xV9FLOjk2teprmtFm7To2OY AP+7TZmP9cd7t4tI3tXONMaBMlnMxktYHLvmgYA/6oFgRv9Nr6V0hQiVtsjgQd4IyI4H666RpTUgSF1g1ribuY4Hup ODxs4xu5jDovP3jXi13P8dWdzU5Xzw2kBJuC03sRljvBByK7Dq zVXp4XHMsAPVvh/dTars+ZL/fjJI++SGygDd30ZtIP1tupuruqm3aOK7YWeHbdjcDOx+8SblN6/68kn2Sen2UsD5nhjBdxw5DiTyC6Jo6gbDG1jRgBwtc73Hmc1Z0 ToWOnbZgxObnYuP8clkF1eLxek/1o3v2ERFvYC8svUQEREBERAREQEREBERAREQEREBERAREQEREB UPiBzF1WiCG7RMZNy3a5Oc4j0JsVKZGAAAAAMAALBVIpJJ/DoiIqCIiAiIgIiICIiAiIgIiICIiAiIgIiICIiAiIgIiICIiAi IgIiICIiAiIgIiICIiAiIgIiICIiAiIgIiICIiAiIgIiICIiAi IgIiICIiAiIgIiICIiAiIgIiICIiAiIgIiICIiAiIg//2Q==[/IMG]
DrHicks is offline   Reply With Quote
no water at sink after water heater removal rebelbull Plumbing 2 07-19-2011 12:37 AM
Water Hammer/Slow Shutoff in New Kitchen Sink? tokey666 Plumbing 2 03-05-2010 06:23 AM
Kitchen Faucet Cold Water Runs Hot Mthrboard Plumbing 8 08-02-2009 06:59 AM
no hot water in kitchen sink acb Plumbing 7 05-02-2009 03:25 AM
Draining a hot water heater singforsupper Plumbing 1 06-07-2006 06:01 PM
