Help Installing Toilet Please - Plumbing - DIY Home Improvement | DIYChatroom
Old 10-23-2012, 09:37 AM   #1
Rewards Points: 91
help installing toilet please
Hi:
The old toilet in the main floor bathroom was leaking and not working properly for quite a while now. It wouldn't flush properly and a variety of other problems. I bit the bullet and bought a new toilet only to find that the toilet flange is 11 1/4" from the wall. The new toilet requires the flange to be 12" from the wall. After measuring the old toilet, I found that it too needs a 12" rough-in. The flange can't be moved without removing a joist. Any suggestions as to how I might jury rig a toilet install of the new toilet until the bathroom renovation takes place next year?
Thanks for the help.
Allthunbs is offline   Reply With Quote
Old 10-23-2012, 09:43 AM   #2
Rewards Points: 13,732
Bring it back and get a 10" rough in toilet.
http://www.amazon.com/s?ie=UTF8&keyw...h%20rough%20in
Old 10-23-2012, 10:04 AM   #3
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,214
Did you actually try installing the toilet? I have never seen a 12" rough toilet that would not work with 11.25"
Try a dry fit without the wax ring or the tank installed. Then set the tank in place and see if it clears the wall.
Coastal South Carolina
Old 10-23-2012, 03:45 PM   #4
Rewards Points: 91
Thanks RJNiles,
I've shoe-horned it in thanks to an extra layer of wax ring. The toilet was one of the one-piece jobs with the buttons on top. Even connecting the water supply was a major pain in the butt. I've already decided that I'm going to rebuild the bathroom and relocate the toilet.
The next problem is how to take a chunk out of the joist to be able to clear the soil elbow around the joist. I'm lucky, I have a supporting wall just below the location (I hope). Suggestions on how to rough this in when I get to it?
Thanks too, JoeCaption, we almost did that. Hopefully, this solution will work properly for the short term. Long term will be to rebuild the bathroom in a year or so.
how do i tell what size "rough in" my current toilet is? liverlipsyyz Plumbing 12 07-20-2012 01:39 PM
installing plastic toilet flange ratherbefishing Plumbing 1 06-16-2012 02:30 PM
Installing a new toilet flange - before or after tiling WoodmanFL Plumbing 9 01-21-2012 08:29 PM
Toilet wont drain chazlew Plumbing 11 02-27-2011 10:08 PM
installing tile. Toilet against the wall joemcjr Building & Construction 4 02-16-2009 08:49 PM
