-   -   help installing toilet please (http://www.diychatroom.com/f7/help-installing-toilet-please-160910/)
Allthunbs 10-23-2012 10:37 AM
Hi:
The old toilet in the main floor bathroom was leaking and not working properly for quite a while now. It wouldn't flush properly and a variety of other problems. I bit the bullet and bought a new toilet only to find that the toilet flange is 11 1/4" from the wall. The new toilet requires the flange to be 12" from the wall. After measuring the old toilet, I found that it too needs a 12" rough-in. The flange can't be moved without removing a joist. Any suggestions as to how I might jury rig a toilet install of the new toilet until the bathroom renovation takes place next year?
Thanks for the help.
joecaption 10-23-2012 10:43 AM
Bring it back and get a 10" rough in toilet.
http://www.amazon.com/s?ie=UTF8&keyw...h%20rough%20in
rjniles 10-23-2012 11:04 AM
Did you actually try installing the toilet? I have never seen a 12" rough toilet that would not work with 11.25"
Try a dry fit without the wax ring or the tank installed. Then set the tank in place and see if it clears the wall.
Allthunbs 10-23-2012 04:45 PM
Thanks RJNiles,
I've shoe-horned it in thanks to an extra layer of wax ring. The toilet was one of the one-piece jobs with the buttons on top. Even connecting the water supply was a major pain in the butt. I've already decided that I'm going to rebuild the bathroom and relocate the toilet.
The next problem is how to take a chunk out of the joist to be able to clear the soil elbow around the joist. I'm lucky, I have a supporting wall just below the location (I hope). Suggestions on how to rough this in when I get to it?
Thanks too, JoeCaption, we almost did that. Hopefully, this solution will work properly for the short term. Long term will be to rebuild the bathroom in a year or so.
