Old 01-25-2008, 06:54 AM   #1
help with immersion heater
hey guys, can anyone help, having a problem with immersion heater, should the taps around it be turned clockwise or anti-clockwise?
frank1980 is offline   Reply With Quote
Old 01-25-2008, 07:32 AM   #2
Master General ReEngineer
Bondo's Avatar
Ayuh,....
What are the Problems,+ What are you trying to Do,..??
Old 01-25-2008, 07:47 AM   #3
bascically,my heating went down,which is powered by a combi boiler downstairs,that is all fixed now.but, before the repair was carried out i was messing with the taps upstairs in the airing cupboard..just want to make sure all is ok..also the light on my electric immersion heater seems a bit dodgy,only stays on if i keep it pressed...it heated up the water yesterday but today is not working..
Water heater problem bear1957 Plumbing 23 11-01-2007 04:53 PM
Chimney Liner for Water Heater mruggeri001 HVAC 6 01-10-2007 07:08 AM
Baseboard heater Help! jweinstock Electrical 6 10-28-2006 05:01 PM
Periodic release from (I think) the T&P valve on the water heater alexz Plumbing 3 08-15-2006 11:31 AM
Immersion heater georgie HVAC 1 02-17-2004 10:31 PM
