Help with ID'ing bathtub sound...
Hello all,
Hope someone can help me. I just bought my first home and it is a brand new townhome. So far everything is fine but recently I've begin to hear a metal poping noise when I get into the bathtub (standing for showers) or if sit on the edge of the bathtub. This noise only happens when I'm standing or sitting at the drain end. I also notice or feel the bathtub has a tiny bit of "flex" by the drian in the bathtub while the other end feels solid. I hope I have discribed my bathtub tub noise well enough for someone to provide some insite before I call the builders. Just a note that my second bathroom's bathtub does not have this problem Thanks for the help. |
Sounds like rub is flexing, tub was not set in a bed of mortor
Is this a metal, acrylic or other tub?
Thanks. |
Is there an access panel for the plumbing near the tub drain?
Did you have this townhouse built or did you buy it from another individual? |
This townhouse was build brand new and I am the first owner. I'm also planning to talk to the another homeowners in this phase to see if they are experiencing the same thing but right now since it is cold out no one is outside unless shovelling the snow. |
Being brand new, any problems for the first year should be covered by a warranty. The tub may not be thick enough steel to keep from flexing. This is why mortar beds are installed under acrylic tubs. The noise may be the drain piping moving when the tub flexes. This will eventually break the piping or slip joints which will cause leaking. Access panels are usually installed during construction so repairs can be made later without cutting out the wall. It is possible that you could be responsible for damages to any other units (if there are any below you) due to leaks. Check with the builder about warranties.
With the info I have recieved I can now talk to the home builders and talk to them sounding like I know what I'm talking about. Thanks |
I forgot to ask but if repairs are to be done by the home builder and lets say it is the mortar bed was not sufficient what are some of the ways they would fix the problem, would they have to take the tub out and redone the bedding or would they just shim the tub (not sure if this proper fix up)?
I remember an old episode of Mike Holmes from Homles on Homes fixing a bathtub problem and when he took the tub out there looked to be a block of styrofoam under the tub... is that a mortar bed? Thanks again. |
Can you post a photo? |
If they have messed up does this mean they will have to redo the mortar bed? |
They will need to find or create a way to look below the tub. |
| All times are GMT -4. The time now is 01:05 PM. |
