Help Identifying A Shower Faucet Cartridge.. Please.. - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-24-2014, 12:51 PM   #1
Rewards Points: 2
Help Identifying a shower faucet cartridge.. please..
Hey Folks,
I have a slow leak in my shower and was attempting to change the cartridge behind the lever of the on / off for the shower. It looks like the standard Moen from the outside and I thought it was as the other items in my washroom is Moen... but upon opening it.. I have no idea what type of cartridge this could be.
If anyone can offer any advice on what brand / make / model this could be would be helpful.
Also, if you know how to remove it, please let me know. I am an amateur at this.. but it didn't seem to be too difficult (if it was a true Moen).
Thanks in advance.
Kind Regards,
W
Help Identifying a shower faucet cartridge.. please..-img_20141222_120540.jpg   Help Identifying a shower faucet cartridge.. please..-img_20141222_120600.jpg   Help Identifying a shower faucet cartridge.. please..-img_20141222_120607.jpg
Drakes25 is offline   Reply With Quote
Old 12-24-2014, 03:41 PM   #2
Looks like the 1225. Once removed, take it with you to a local plumbing, hardware, or big box store and match it up. Usually stocked locally. Or if you can wait about a week or so call moen and they will send you one for free.
To remove; Remove the 2 screws on esechon plate and remove plate (flat tip screwdriver helps). Pull off stop tube by hand, remove retainer clip with pair of needle nose pliers, remove cartdrige by working up/down with pair of pliers. May be coated with sediment, hit it with some wd40 or pb blaster, tap it a little bit, let it set for awhile if needed. Remember or take pictures of the cartdrige position. Reverse process for new cartdrige install. It has to go back in same way. No biggy, if it doesn't work right when you put it back together, just flip cartdrige 180 degress.
There are also youtube videos on this process as well if needed. Just a suggestion.
jmon is offline   Reply With Quote
The Following User Says Thank You to jmon For This Useful Post:
gregzoll (12-24-2014)
Old 12-24-2014, 04:21 PM   #3
DIY staff
Rewards Points: 7,174
I don't think that is a moen----
The Following 2 Users Say Thank You to oh'mike For This Useful Post:
jmon (12-24-2014), SHR Plumber (12-26-2014)
Old 12-24-2014, 04:30 PM   #4
Rewards Points: 582
agree with mike ...its not a moen ....may need to pull that one to see if it can be matched ..can't say if i ever seen that one....sorry...
The Following User Says Thank You to ben's plumbing For This Useful Post:
jmon (12-24-2014)
Old 12-24-2014, 05:12 PM   #5
Rewards Points: 6,652
That plate is pretty scratched up. I would contact the mfg to get a new plate and you may score on a free replacement cartridge.
Old 12-24-2014, 07:40 PM   #6
Rewards Points: 558
That looks like a peerless cartridge
epson is offline   Reply With Quote
Need Help Identifying Shower Valve (Faucet) Homecrafters Plumbing 4 10-01-2014 05:35 PM
How to patch holes in shower enclosure when going from 2-handle faucet to single? Studly Plumbing 7 05-24-2013 10:20 AM
How Do I Remove A Moen Shower Faucet Cartridge kgkings Plumbing 23 10-11-2011 06:08 AM
My shower head leaks when tub faucet is running? Walter Sobchak Plumbing 4 05-24-2010 08:13 AM
Faucet Cartridge removal -- what should I have done? RippySkippy Plumbing 9 08-20-2009 08:49 AM
