Help Identifying My Basement "rough In" Plumbing - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-28-2012, 10:44 AM   #1
Working up to "novice"
dean2dana's Avatar
Question
Help identifying my basement "rough in" plumbing
Hi, I am looking to finish my basement and I am having trouble wrapping my head around the piping (and options) I have in the basement for a bathroom. I am including several pics because my explanations of what I think I see may only confuse the issue. I have labeled the things as I understand them to be...if I am incorrect...sorry. I just want to have a solid idea of what I have so when I talk with a plumber in my area I will at least be knowledgeable enough to know when he is telling me something that is not correct(options wise). Thanks for any and all help.
** Also, just fyi, my basement drains are below my "main" home drain...see pics.
Actual door is just off pic to the right/door in center of pic will be removed(framed in)
dean2dana is offline   Reply With Quote
Old 11-28-2012, 11:21 AM   #2
Plumber
TheEplumber's Avatar
Rewards Points: 684
Your almost done.
That pit is for a sewer pump. Those pipes you call a trap are actually the sewage pump ejection line connected to the pump vent- the one you are holding is the pump line to the future pump. The vent should be tied in on or above the first floor as you suggested. The sewage pump needs a 2" vent, so those two pipes will run independently to the pump basin(once the 90's are cut off). Not sure why the plumber has them looped together.
The Following User Says Thank You to TheEplumber For This Useful Post:
dean2dana (11-28-2012)
Old 11-28-2012, 11:42 AM   #3
dean2dana's Avatar
Guidance on the rest of the piping shown in bath area
Hey E...thanks for the input. Could you give me some guidance on the actual bath area piping and layout? Is the pvc in the center of the floor an actual drain for a tub/shower? Are the pipes(2") against the concrete wall for a sink area? Vent for the toilet? Just trying to shore up what little knowledge I have on the matter. Thanks again.
Old 11-28-2012, 12:03 PM   #4
Plumber
Rewards Points: 684
The pipes at the concrete are a toilet vent- behind the toilet stub and a rough in for a lav. The toilet stub itself needs to be 12" from its center to the face of your finished wall. This tells you where to put your wall furring.
The pipe in the middle seems to be for a tub or shower. Usually, we put a box in the floor where the trap goes for the proposed fixture- don't see one in your pictures tho.
Old 11-28-2012, 12:07 PM   #5
dean2dana's Avatar
Tub/Shower trap
Does that mean that I will have to break up the floor around the "center pipe" to determine if there is or is not a trap in the floor already? Obviously...every erroneous step/work I can avoid is money/time in my pocket. Thanks again for your time...greatly appreciated!
Old 11-28-2012, 12:22 PM   #6
Plumber
Rewards Points: 684
I would start by getting a hammer out a tapping the floor- listening for hollow sounds- much like tapping a wall to find a stud.
Some times the box is set slightly low(below top of concrete) either by accident or not knowing exact floor elevation. Sometimes its just not put in.
A tub trap would be almost next to the pipe, a shower trap about 18" away(36x36 shower) Good luck
Old 11-28-2012, 01:13 PM   #7
dean2dana's Avatar
Thanks again for all your input...really appreciated.
Old 11-28-2012, 01:51 PM   #8
Plumber
Rewards Points: 684
Not a problem. Ya know, the hard work is done- consider doing the balance yourself.
Sent from my iPhone using DIY Forum
Old 11-29-2012, 06:39 AM   #9
dean2dana's Avatar
Smile
Yeah...I have been turning it over and over in my head...a definite "maybe" that I will complete everything myself. Well...with some help from kind people like yourself!
Old 12-04-2012, 07:20 PM   #10
dean2dana's Avatar
Found it.
http://i1193.photobucket.com/albums/...a/IMG_0095.jpg
Found it right next to the pipe...really did not think it would be that close to the pipe. Thanks again.
The Following User Says Thank You to dean2dana For This Useful Post:
TheEplumber (12-04-2012)
Tags
basement , rough-in
Plumbing runs on basement outside wall n0c7 Plumbing 8 01-19-2012 05:22 PM
Extending Basement Plumbing rhys Plumbing 1 12-09-2011 07:19 AM
How to design plumbing drainage in basement sonicsmooth Plumbing 0 02-02-2011 01:55 AM
ANOTHER - basement plumbing picture mazzonetv Plumbing 6 03-12-2010 02:35 PM
Open Plumbing in Basement WannabHomeOwner Plumbing 8 09-12-2009 08:08 AM
