Help Identifying Bathroom Rough In Pipes - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-08-2012, 10:02 PM   #1
Rewards Points: 12
Help identifying bathroom rough in pipes
I am trying to identify the pipes for my basement bathroom rough in. Any ideas? The far pipe with the 12"x12" knockout is 2" and i am guessing it is for a shower. The other narrow pipe is a 1.5" pvc pipe. Any help would be appreciated, my last resort will be jackhammering.
diystl is offline   Reply With Quote
Old 12-08-2012, 10:09 PM   #2
Plumber
TheEplumber's Avatar
Rewards Points: 676
heres my guess
4" toilet stub
3" clean out and toilet vent/ lav waste
1.5" shower vent
Old 12-12-2012, 10:14 PM   #3
Rewards Points: 12
Originally Posted by TheEplumber
heres my guess
4" toilet stub
1.5" shower vent
Thanks for the input. What do you mean by 3" clean out and toilet / lav waste? I am having problems visualizing what is going on under the slab could you sketch it?
Old 12-12-2012, 11:23 PM   #4
Plumber
Rewards Points: 676
The end of the building drain needs a clean out by code, In your case, it also needs to be 3" So you put a clean out tee on that riser at what ever height you want. Then reduce the top of the tee to 2" and now it is the toilet vent.
If you want a lavatory sink to the left of the 3", you can add a tee to arm down the wall to your lav location. The lav will drain into the 3" clean out/toilet vent. This is known as wet venting. Hope this helps
Old 12-13-2012, 12:38 AM   #5
Rewards Points: 13,730
The 2" would be a tub or shower drain.
Old 12-15-2012, 06:15 PM   #6
Rewards Points: 12
See my sketch below. Is this what you mean by wet venting? Thanks for all the info it looks like i wont need to jackhammer any concrete!
Old 12-15-2012, 06:41 PM   #7
Plumber
Rewards Points: 676
Attachment 62049
That looks right. you could lower the clean out so its near the floor- bush it down to 2" then add a 2x2x1.5" lav tee on top- only the clean out needs to be 3". That would keep you from buying a 3x1.5 tee (spendy). Put the lav tee at 19" above the floor (center of the branch outlet) That will work for most lav heights
Old 12-15-2012, 06:44 PM   #8
Rewards Points: 2,238
The 4 inch is for the toilet.
The 3 inch is a vent stack.
The 1.5 inch is for a vanity (although, it could be a re-vent).
The 2 inch is for a shower (You'll have to trap that - under the concrete
floor)
If the 1 1/2 inch is too close to the shower (for a vanity) - you could move
the vanity toward the 3" pipe - "T" off the 1 1/2 inch pipe, run it into the
3 inch pipe, as a drain for the vanity.
Off the top of the "T" on the 1 1/2 inch pipe - run it into the 3 inch pipe as
a re-vent (above the "flood-rim" of the vanity).
As "TheEplumber" says - "clean-out" on the 3 inch pipe.
rossfingal
(Something has to be tied into a vent-stack that goes through the roof - probably, the 3 inch pipe)
rossfingal is offline   Reply With Quote
Old 12-15-2012, 10:41 PM   #9
You do not think they trapped the tub already?
paintdrying is offline   Reply With Quote
Identifying rough in pipes and capping drain/vent? simonh Plumbing 4 06-10-2012 08:39 PM
Basement Bathroom Rough In Questions Mike Fox Plumbing 10 11-10-2011 08:35 AM
Freezing pipes in master bathroom need a 993 Plumbing 8 11-29-2009 06:10 PM
basement bathroom rough in - framing questions twobabieslater Building & Construction 2 12-29-2008 02:56 PM
Replacing pipes in bathroom, need advice Steelmesh Plumbing 7 11-04-2008 11:30 AM
