Help Identify Rough-In Bathroom Components - Plumbing - DIY Home Improvement | DIYChatroom
Old 09-20-2012, 12:29 AM   #1
Post
Hello Group,
I was wondering if anyone could help me identify some components of my basement rough-in bathroom. This is located on the ground floor of a three floor townhome. The bathroom was roughed-in by the builder when the townhomes were built 5 years ago. I just moved in a year ago.
I'm pretty sure I've identified the toilet and vanity locations. There's one pipe sticking out and capped which I have no idea what it's for. I thought it was a drain for a tub/shower but there's no water (hot and cold) pipes nearby.
Picture Breakdowns:
(1st Pic) ToiletAndUnknown.jpg = The toilet is on the left but the pipe on the right is unknown.
(2nd Pic) Unknown_CloseUp.jpg = There's styrofoam around this pipe.
(3rd Pic) Toilet_CloseUp.jpg = Not sure what the pipe covering in the wall is for.
(4th Pic) Vanity.jpg = Picture of the Vanity
(5th Pic) Vanity_CloseUp.jpg = Not sure what the bottom hole showing the pipe is for.
Any help is much appreciated!
/Baz
Help Identify Rough-In Bathroom Components-toiletandunknown.jpg   Help Identify Rough-In Bathroom Components-unknown_closeup.jpg   Help Identify Rough-In Bathroom Components-toilet_closeup.jpg   Help Identify Rough-In Bathroom Components-vanity.jpg   Help Identify Rough-In Bathroom Components-vanity_closeup.jpg
GeneralBaz is offline   Reply With Quote
Old 09-20-2012, 09:30 AM   #2
Plumber
TheEplumber's Avatar
Rewards Points: 452
First picture = toilet and shower
second= shower p trap riser
third = toilet, toilet water supply, clean out
fourth = lav waste, clean out and water
The Following 2 Users Say Thank You to TheEplumber For This Useful Post:
ben's plumbing (09-20-2012), GeneralBaz (09-20-2012)
Old 09-20-2012, 09:47 AM   #3
@ePlumber-
what is the generally accepted min size for a shower drain? 1.5 or 2"?
allthumbsdiy is offline   Reply With Quote
Old 09-20-2012, 09:58 AM   #4
Plumber
Rewards Points: 452
Originally Posted by allthumbsdiy View Post
@ePlumber-
2" is code
equal to 2 drainage fixture units(DFU)
allthumbsdiy (09-20-2012), ben's plumbing (09-20-2012)
Old 09-20-2012, 12:25 PM   #5
Thanks ePlumber!!
So it is a shower drain. If I didn't want to put a shower in this washroom what should I do with that pipe and styrofoam around it?
/Baz
Old 09-20-2012, 12:51 PM   #6
Plumber
Rewards Points: 452
Originally Posted by GeneralBaz
Thanks ePlumber!!
/Baz
Dig out the styrofoam, cut the pipe well below the floor line and cap it with a permanent type glue cap. Cover it with plastic and pour back your floor.
You should find a p trap down there- cut on either side of it
Sent from my iPhone using DIY Forum
Tags
basement bathroom , rough in
multiple choice - basement bathroom venting debacle and burps denemante Plumbing 1 11-15-2011 11:50 AM
Basement Bathroom Rough In Questions Mike Fox Plumbing 10 11-10-2011 09:35 AM
Bathroom DWV Layout Problems grymes56 Plumbing 8 05-15-2011 10:00 AM
From a rough to a bathroom Satori Plumbing 4 07-21-2010 07:52 PM
Basement Bathroom Rough In snowwhite49 Plumbing 2 05-26-2008 10:11 AM
