Help ID Laundry Water Valve Cover - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-28-2008, 10:15 AM   #1
Builder left as is. I need a cover but can not find the exact model. Any clues? If I can't find one is it hard to install a brand new complete box? Will some of the dry wall need to be removed to install a new box?
Any suggestions?
phillyd2 is offline   Reply With Quote
Old 01-28-2008, 10:47 AM   #2
Long-Time DIYer
Mike Swearingen's Avatar
I wouldn't replace all of that, which would involve re-plumbing and drywalling.
Just install some off-the-shelf wood trim around the opening with Liquid Nails and tacks, paint it to match the wall, and you're good-to-go.
Mike
Mike Swearingen is offline   Reply With Quote
Old 01-28-2008, 11:05 AM   #3
Custom Cabinet Maker
Damn Mike ya snuck that in before I could type it ROFLOL
skymaster is offline   Reply With Quote
Old 01-28-2008, 11:10 AM   #4
makes sense. suggestions for the trim? I guess the corners need to be cut on a angle to go together nicely. Do they sell them with the ends already cut?
Replace toilet water shutoff valve abastin Plumbing 14 02-14-2011 03:41 PM
Master (water) shutoff valve rmdyjoe Plumbing 7 12-05-2008 08:55 AM
Replacing water heater drainage valve darsunt Plumbing 2 10-08-2007 09:17 PM
Main valve not working. Water won't turn on! skellies Plumbing 1 10-31-2006 02:17 AM
Periodic release from (I think) the T&P valve on the water heater alexz Plumbing 3 08-15-2006 10:31 AM
