Help With How To Remove Shower Drain - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-13-2010, 07:14 PM   #1
help with how to remove shower drain
I have a home in So California built in 1969 and I am removing the fiberglass based modular shower to replace it with something that isn't gross! I have a concrete slab home and the shower drain appears to go directly down through the shower pan into the plumbing. There was nothing below the top grate but an open hole, no strainer and the ring around the pipe is so coorroded I can't tell how to remove it.
I am afraid of damaging the plumbing in the slab as it looks like very little pipe is sticking up above the concrete.
Any suggestions on hos to remove the existing drain collar and get the shower surround out without damaging the drain pipe would be greatly appreciated.
jcon3678 is offline   Reply With Quote
Old 12-13-2010, 08:15 PM   #2
DIY staff
Rewards Points: 7,174
You mentioned rusty pipe and 1969---so I figure you have iron pipe--
Here is how I usually do it--cut out the fiberglass pan as near to the drain as you can without hitting the actual drain cup. I usually make a series of plunge cuts with a skillsaw to free up the pan--
A sawsall would do the same,just cost you a bunch of blades---
Once the pan is gone you should have a pipe with some fiberglass --using a sawsall with a metal blade --split the fiberglass (and the metal drain cup--Which is packed with lead) until you just touch the old drain pipe----drive a big screw driver or chisel into the split and open up the drain cup--
The old drain cup and bits of fiberglass should just lift off--Done--10 minutes--Mike--
Install Tile Shower Base Drain -- Advice Needed unionmaid Kitchen & Bath Remodeling 11 12-30-2013 09:30 AM
1 1/2" shower drain tlynn Plumbing 3 02-25-2010 05:09 PM
shower drain vs tub drain--connected to toilet???? mandalala Plumbing 2 06-24-2009 02:00 PM
Installing stand-up shower in finished basement without existing drain notenoughtime Plumbing 3 05-16-2009 11:59 AM
Shower drain relocate fireman74 Plumbing 3 12-29-2008 11:46 PM
