Old 06-20-2012, 04:56 PM   #1
HELP with hose attachment!
Hi all,
I am trying to attach a 2" Dia rubber hose to a one inch flange (ledge) and cannot drill into it. Is there some sort of locking clamp that I can use to attach the hose to the flange? This is under my car body so it vibrates a lot and cannot be too obtrusive. Sorry for the strict criteria but any reccomendations are much appreciated!
Thanks,
W
wikur is offline   Reply With Quote
Old 06-20-2012, 06:21 PM   #2
I don't have a clue what you are talking about.
danpik is offline   Reply With Quote
Old 06-20-2012, 06:45 PM   #3
Let's try this with you posting a picture of what you have there and a bit more informative text about what it's supposed to be.
Evstarr is offline   Reply With Quote
Old 06-25-2012, 02:05 PM   #4
Sorry, a picture probably would have cleared things up. This is just a sketch of what the optimal clamping device may look like. I need to have 3 or 4 of these things to hold the hose up from dragging on the ground.
Old 06-25-2012, 02:45 PM   #5
Lightfoot's Avatar
is this a temporary thing, or for permanent?
Still not 100% sure of what you're trying to do, but
it looks like a series of small c-clamps might work.
http://www.harborfreight.com/6-inch-...amp-37850.html
never mind. I read your first post again. C-clamps would loosen with vibration, unless you spot welded them or something.
Lightfoot is offline   Reply With Quote
Old 06-26-2012, 12:34 AM   #6
Persona Non Grata
VIPlumber's Avatar
So this hose is supposed to be clamped under your car? What type of fluid is this going to be used for?
VIPlumber is offline   Reply With Quote
Old 06-26-2012, 10:31 AM   #7
Doing it myself
Alan's Avatar
Try something like this, and then attach a stainless steel hose clamp through it or something.
http://www.grainger.com/Grainger/ANV...120626143019:s
For added peace of mind about vibration, swap the nut out for a nylock.
Journeyman Plumber
Tags
clamping, hose, no drilling, pipe
Sprayer hose removal zubby01 Plumbing 0 07-29-2011 01:51 PM
Kitchen Sink Hose Attachment Question cliffhuxtable Plumbing 3 04-28-2011 06:20 PM
Simple hose connection? BataviaJim Plumbing 6 03-25-2010 01:52 PM
outside faucet sprays at head attachment Synthia212 Plumbing 11 03-13-2009 06:53 AM
garden hose water spillage questions mcvane Landscaping & Lawn Care 10 07-29-2007 01:27 AM
