-   -   HELP with hose attachment! (http://www.diychatroom.com/f7/help-hose-attachment-147716/)
wikur 06-20-2012 04:56 PM
Hi all,
I am trying to attach a 2" Dia rubber hose to a one inch flange (ledge) and cannot drill into it. Is there some sort of locking clamp that I can use to attach the hose to the flange? This is under my car body so it vibrates a lot and cannot be too obtrusive. Sorry for the strict criteria but any reccomendations are much appreciated!
Thanks,
W
danpik 06-20-2012 06:21 PM
I don't have a clue what you are talking about.
Evstarr 06-20-2012 06:45 PM
Let's try this with you posting a picture of what you have there and a bit more informative text about what it's supposed to be.
wikur 06-25-2012 02:05 PM
1 Attachment(s)
Sorry, a picture probably would have cleared things up. This is just a sketch of what the optimal clamping device may look like. I need to have 3 or 4 of these things to hold the hose up from dragging on the ground.
Attachment 53021
Lightfoot 06-25-2012 02:45 PM
is this a temporary thing, or for permanent?
Still not 100% sure of what you're trying to do, but
it looks like a series of small c-clamps might work.
http://www.harborfreight.com/6-inch-...amp-37850.html
never mind. I read your first post again. C-clamps would loosen with vibration, unless you spot welded them or something.
VIPlumber 06-26-2012 12:34 AM
So this hose is supposed to be clamped under your car? What type of fluid is this going to be used for?
Alan 06-26-2012 10:31 AM
Try something like this, and then attach a stainless steel hose clamp through it or something.
http://www.grainger.com/Grainger/ANV...120626143019:s
For added peace of mind about vibration, swap the nut out for a nylock.
