HELP...Holes Drilled In 2 X 4 LBW - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-15-2010, 01:29 PM   #1
HELP...Holes drilled in 2 x 4 LBW
Hi all,
I'm installing a 1 1/2" vent line for a shower. I need to run this line up from the basement floor into a 2x4 stud wall; then across through 2 parallel LOAD BEARING WALL studs to the main stack. I need to know if I can drill a 2" hole through both of those studs. The run is a about 3 feet across.
I know the code states up to 40% of the depth of the stud for 2 x 4 LOAD bearing walls. Which works out to 1 7/16" hole only. Any help would really be appreciated..
thank you.
acfrqflyer is offline   Reply With Quote
Old 11-15-2010, 02:58 PM   #2
Homerepairguy's Avatar
Rewards Points: 990
The diameter of drilled holes in studs should not exceed 40 percent of the stud depth, and the minimum edge distance to the boundary of the hole shall not be less than 5/8-inch. When studs are doubled, drilled holes should not exceed 60 percent of the stud depth. Holes of maximum diameter should not occur in more than two consecutive studs. Adjacent holes, or holes and notches should not occur in the same cross section. As an example, a 2x4 can have a maximum hole of 1 3/8-inch or 2 inches if studs are doubled.
Info obtained from here:
http://www.toolbase.org/toolbasereso...1&CategoryID=7
HRG
Homerepairguy is offline   Reply With Quote
Need help caulking and filling nail holes in my trim hadees Painting 13 11-25-2012 11:32 PM
Alternatives for fixing holes in tile roof felt Squash_Pro Roofing/Siding 4 05-13-2010 07:20 PM
1/2" holes drilled every 3" inches around foundation???? amerren Building & Construction 5 04-13-2010 11:45 AM
Block Foundation w/Hundred Seep Holes? Jodust11 Building & Construction 9 04-13-2010 11:41 AM
Help..drilled holes in storm door wrong... rvegab00 General DIY Discussions 2 09-29-2009 10:42 AM
