Help! Hard To Access Pipe! - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-07-2012, 12:03 AM   #1
Help! Hard to access pipe!
I have discovered a leak in the section of my main drain that leads from my kitchen sink. I managed to locate the hole itself by taking out the back panel of the cupboards beside my sink...
However here is the problem. The problem area is so rounded by other pipes and I can not get good access to it.
The hole is rather large and may be 2 holes. There is a section between two connectors that appears to be rusted.
Here are some photos showing what I mean...
Any advice would be greatly appreciated! I am afraid calling a plumber may be very expensive for this one.
THANKS
Lee Swain is offline   Reply With Quote
Old 07-07-2012, 12:24 AM   #2
My images are not showing, so here are links -
IMAGE 1
IMAGE 2
IMAGE 3
IMAGE 4
Old 07-07-2012, 12:45 AM   #3
Plumber
TheEplumber's Avatar
Rewards Points: 834
Your right, a plumber might be spendy for that one.
Best to break your project down to smaller tasks. You need to remove whats in front of the pipe to gain access. Maybe even remove the water lines. Then cut out above and below the drainage tees- do you have access below such as a basement?
Then you can rebuild it using PVC or ABS pipe- join to existing material using Fernco's or, preferably no-hub couplings.
You might discover more pipe that needs repair. It looks like the arm to the sink has already been replaced- possibly for the same reason.
Greetings from San Clemente Ca: Access Door Install in Skylight Shaft? FINSEEKER Remodeling 1 05-12-2012 05:56 AM
Need to close off or move a vent pipe & drain that goes to nothing mystic_cobra Plumbing 2 04-18-2011 08:14 PM
Well pipe access shutdown HomerRepair Plumbing 6 03-08-2011 09:22 AM
Bernoulli's Principle, increase 3/4" pipe to 1-1/4" or 1-1/2" copper ChrisDIY Plumbing 14 09-18-2010 09:49 PM
Is yellow polyethelene or polyphenol gas pipe now the preferred gas conduit? MarkSilber Plumbing 1 09-18-2010 12:10 PM
