Old 01-04-2008, 09:47 AM   #1
Help fitting concealed shower valve
Hi there.
Could anyone please tell me, when looking at the back of triple concealed thermostatic shower valve, make is Pura LV333, which side does the hot water pipe go in, left or right? Any help would be great and save me some time and money.
Cheers and thanks again
Ben
beeen is offline   Reply With Quote
Old 01-04-2008, 09:49 AM   #2
Master General ReEngineer
Bondo's Avatar
Ayuh,....
Usually the Hot is on the Left,+ Cold should be on the Right......
Old 01-04-2008, 09:57 AM   #3
cheers bondo, so looking at the back where all the inlets and outlets for the water are, the hot goes on the left. Sorry if I am sounding stupid, just want to make sure and double check its not the left when looking at the faceplate and control side.
Many thanks Ben
Old 01-04-2008, 10:26 AM   #4
Bondo's Avatar
Ayuh,.....
When standing in front of a faucet,.....
The Hot Should be coming in from the Left,+ the Cold Should be coming in from the Right........
Of course,....
The Key words in my replies are "Usually",+ "Should"..............
Old 01-04-2008, 10:36 AM   #5
Thanks a lot. Have a great new year
Old 01-04-2008, 11:54 PM   #6
Journeyman Plumber
Ron The Plumber's Avatar
If your looking on the back side hot will be on the right cold on left, looking from front side, cold of right and hot on left.
Fix it right the first time, so you won't have to fix it a 2nd time.
Ron The Plumber is offline   Reply With Quote
very low shower head flow rickard681 Plumbing 7 10-08-2008 07:43 AM
aging symmons temptrol shower valve v240969 Plumbing 1 01-01-2008 06:24 PM
Unable to remove Shower valve abacuslearns Plumbing 8 10-27-2007 11:10 AM
Periodic release from (I think) the T&P valve on the water heater alexz Plumbing 3 08-15-2006 11:31 AM
Help, the bakelite light fitting in my shower room smells! Unregistered Electrical 1 08-13-2004 08:03 AM
