Help With Finish Work Please - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-26-2013, 08:35 AM   #16
I wonder what size drain pipe that is? I did not like how big he made the holes. And what is with all those smaller drilled holes?
paintdrying is offline   Reply With Quote
Old 01-26-2013, 10:35 AM   #17
Rewards Points: 4,796
Originally Posted by Beepster View Post
Pex ring crimping is not something to be taken lightly.
Huh? It's pretty easy to tell if a crimp ring is crimped correctly, ya know.
jeffnc is offline   Reply With Quote
Old 01-26-2013, 10:49 AM   #18
langless28's Avatar
Rewards Points: 152
Well I got it all done with no leaks. I crimped and checked each fitting with the g/ng gauge. The only thing that sucked was the cold water was right below the drain so its moved off to the side of the drain pipe. Is that bad? Also for that threaded union on the ptrap, are you suppose to use plumbers putty on it? Or make sure it's seat Ed correctly? Also I did the hole for the drain. We had to lift and slide the cabinet into position since the drain comes out at 45 degrees, hence the large hole. The "tiny holes" are actually screws to hold a piece of ply behind the cabinet so the old work box could be more sturdy. Not my happiest execution but I have screw caps that match the cabinets so I will use those.
langless28 is offline   Reply With Quote
Old 01-26-2013, 10:59 AM   #19
Doing it myself
Alan's Avatar
Rewards Points: 2,086
Why are the hot and cold lines reversed?
Also : I never use metal trim rings on plastic pipe.
Journeyman Plumber
Old 01-26-2013, 11:03 AM   #20
langless28's Avatar
Rewards Points: 152
What do you mean reversed? The mixing valve flex lines are color coded and hooked up to the correct hot and cold lines. Good point on the metal finish rings. I checked and they are rounded on the inner lip. I would need to cut them off now.
Old 01-26-2013, 11:06 AM   #21
Plumber
TheEplumber's Avatar
Rewards Points: 818
Putty is not needed on the trap. But I do use a splash of pipe dope for lubrication
Old 01-26-2013, 11:08 AM   #22
Doing it myself
Alan's Avatar
reversed coming through the bottom of the cabinet. Hot should be on the left.
Journeyman Plumber
Old 01-26-2013, 11:14 AM   #23
langless28's Avatar
Rewards Points: 152
Oh, we'll that's what the plumber did. I just did the finish work.
Old 01-26-2013, 01:38 PM   #24
Goofy. But for something like this it doesn't matter much at the end of the day.
Old 01-26-2013, 01:39 PM   #25
Oh by the way, what is the model of the Waste King? And let me know what you think of it once you try it out....
Old 01-26-2013, 01:44 PM   #26
langless28's Avatar
Rewards Points: 152
It's the 2600 1/2 hp. We compost everything we can so we don't plan on using it a lot. It's darn quite though.
Old 01-26-2013, 02:03 PM   #27
Doing it myself
Alan's Avatar
It's darn quiet though.
That's because waste king doesn't do anything. Just there for looks. They call it waste king because it's a waste of money.
Journeyman Plumber
Old 01-26-2013, 02:06 PM   #28
Typical hyperbole with nothing backing it up.
Rather than take cheap and easy shots like a 12 year old, maybe you could add some relevant facts to that vague claim.
Old 01-26-2013, 02:15 PM   #29
Doing it myself
Alan's Avatar
Oh come on it was a joke.
Besides the fact that a 1/2 hp name brand disposal from insinkerator can be had for 99 bucks?
Journeyman Plumber
Old 01-26-2013, 06:13 PM   #30
Well the fact is I'd really like to know. These things are pretty expensive disposals. The L8000 is like a $350 unit with 1 HP and lifetime in home replacement warranty. But now they're heavily discounted. And I'm wondering.... why?
The obvious guesses are they changed ownership and are cheapened down, or they're going out of business, or.... ?
Eggshell Finish Confusion fjmartinez Painting 5 05-24-2012 08:34 AM
Finish Stripper or No Finish Stripper starkhd Painting 11 02-16-2012 06:15 PM
What type of FINISH for a SMOOTH Finish? jennyusmc Painting 10 03-06-2011 05:59 PM
Duct work in garage. flashme18 HVAC 1 11-08-2009 06:29 PM
