Old 01-14-2010, 06:51 PM   #1
Help finding Cover for Drain Access
I am hoping someone can help me. I am finishing the basement in my house, the main drain stack for the upper bathroom runs through a wall, it is 3in PVC. There is a removable plug in case you need to unclog it, the building inspector told me this has to be accessible, so I dry-walled around it.
I need to find a nice cover and am having a very hard time. There is not much local and I am trying to find one online. The closest thing I have found is here. Anyone know of something similar from a place I can order from? Can this go into PVC?
JETJR is offline   Reply With Quote
Old 01-14-2010, 07:22 PM   #2
http://www.accesspanels.net/
Ishmael is offline   Reply With Quote
Installing and attic access and a "What is this?" cbaileyau General Discussion 16 12-19-2009 03:54 PM
Install manholes (access) hole in concrete septic tank cover rkpatt General Discussion 2 02-23-2009 07:37 PM
Finishing off access door panel TanMan Building & Construction 12 02-05-2009 06:59 PM
Washer agitator/spinner turns one way, but not the other IckesTheSane Appliances 5 01-10-2009 03:53 AM
Fascia cover filled with water/ice causing leaks brianbh Roofing 10 02-11-2008 08:34 PM
