Old 06-15-2012, 04:09 AM   #1
Question
Help to find a valve stem
Hello,
The valve stem in the shower has broken, and I can't find a replacement of a correct size.
This is the closest match I bought:
But it is too long, and if I install it, I don't have any movement to open the water. The length inside the wall on this one is 50mm, and the original was about 45mm.
I tried to search Google Products, Amazon and eBay, for "stem" in the "kitchen and bath" categories, but didn't find anything close. And tried local shops of course.
Any thought on how to better approach this?
Thank you,
Anton.
CTPAYC is offline   Reply With Quote
Old 06-15-2012, 07:52 AM   #2
Danco, which makes a complete line of valves, has displays in home and hardware stores. They may not have all the models at the store, but their book does. Match up yours with their book and order from the store or online.
Old 06-15-2012, 08:04 AM   #3
JetSwet's Avatar
What was the issue with the stem? Is there a seat inside the shower body? A plumbing store should tell you what type it is and match it.
JetSwet is offline   Reply With Quote
Tags
shower, stem, valve, valve stem, water
Need help: Broken stem in Moen shower faucet valve cartridge Learning Lots Plumbing 9 05-04-2012 11:56 AM
Lost bleeder cap on valve - can't find right size jocco Plumbing 5 04-05-2010 12:52 PM
help me find a valve jimmy21 Plumbing 7 05-10-2009 01:37 PM
Leaking pressure relief valve Chris Magee Plumbing 12 08-12-2008 08:48 PM
Toilet: water still coming from BOTTOM of Inlet Valve DIY Mom Plumbing 1 08-12-2008 01:43 PM
