Old 03-26-2008, 04:26 PM   #1
Help Extending Hoses, etc. for Washer/Dryer
I need to move my washer and dryer about 12 feet total. 6 feet down, then right angle another six feet.
Right now they have the standard hoses and plugs.
Both washer and dryer have the steam feature, so they both need hot water.
Is there a maximum length, or potential problem with just buying longer hoses, pigtails and vents?
I would like all the pro's and con's.
Where would be a good place to find these hoses and pigtails?
Re-plumbing would be too expensive.
graphicsource is offline   Reply With Quote
Old 03-26-2008, 04:43 PM   #2
Send a message via AIM to Marlin
For a hose that long you would need to go to a garden center. You need to move the water supply lines to do this right.
It's hard to say anything about the vent without seeing it but their is a maximum distance you can run a vent and you can only have so many bends in it.
Marlin is offline   Reply With Quote
Old 03-27-2008, 06:57 AM   #3
Cons: hoses all over your walls.Vent hose to long for your dryer/over working your brand new appliance,voiding your warranty.220V pig tail exposed on your wall.
Pro`s: Hire one or maybe two.1:Plummer 2:Electrician
mark942 is offline   Reply With Quote
FloodSafe Washing Machine Hoses IdahoBob Plumbing 13 10-29-2011 05:23 PM
Testing a Central Vacuum with no hoses or heads MrLinux General Discussion 1 01-23-2008 04:44 PM
Extending a GFCI in the bathroom diamondking Electrical 10 05-01-2007 06:48 PM
