Old 10-07-2009, 10:05 PM   #1
Default Help!! Elect Hot Water Heater
Hi
We just changed both elements in a 50 gal elect water heater. When we turned the breaker back on - nothing happened. current going into water heater and at both elements. Still nothing. Any suggestion would be appreciated. Thanks!
robbieimb is offline   Reply With Quote
Old 10-07-2009, 10:18 PM   #2
Master Plumber/Mechanical
Brand of water heater?
Is this an energy effec WH?
John Wayne once said "Life is tough and it is even tougher if you are stupid"
Arcoaire and Trane Dealer
Old 10-07-2009, 10:23 PM   #3
Default Water Heater - Energy Efficient
Hi
Thanks for reply. It is an energy efficient "enviro-temp". Any suggestions would be appeciated.
Old 10-07-2009, 10:32 PM   #4
Most of the energy eff WH take 10-15 minutes to do a system test before the control board will send power to the elements
Old 10-07-2009, 10:39 PM   #5
Default Thanks
We're going to try this again. Thanks so much for your suggestion. You are appreciated.
Old 10-07-2009, 11:08 PM   #6
Default Thank you! Thank you! Thank you! Thank you!
Thank you! Thank you! Thank you! Thank you!Thank you! Thank you! Thank you! Thank you!Thank you! Thank you! Thank you! Thank you!Thank you! Thank you! Thank you! Thank you!
Old 10-07-2009, 11:45 PM   #7
Glad it worked
More On This Topic
What is External Qigong?
What is External Qigong? by Expert Village
In the external Qigong therapy, one of the most recognized projecting qi is the infrared rays, which mainly stem from the increasing skin temperature caused by the strengthening parasympathetic tone during Qigong exercise. Today, modern instruments have... Read More »
Qigong Breathing Therapy
Qigong Breathing Therapy by Expert Village
Welcome to Ace Acupuncture Clinic of Milwaukee. I am Dr. Jin, the chief acupuncturist of this clinic and the honorary professor at Guangzhou Univ. of Traditional Chinese Medicine, China. I began to learn Qigong from Master Jiao of China since the early... Read More »
Acne and other skin disorders affect millions of people each year. Some have used ozone therapy as an alternative treatment. Purportedly, by injecting ozone into the skin, ozone therapy boosts oxygen levels while it detoxifies impurities and deeply... Read More »
Certain forms of internal Qigong can be used for patients suffering from chronic fatigue syndrome, or people with mental or physical fatigue. The famous Eight-section of brocade Qigong or Energizing Qigong developed by Master Jiao is suitable to reduce... Read More »
Popular qigong exercises called Eight Pieces of Brocade; learn the meditative, spiritual side of Shaolin Kung Fu in this free martial arts video series. Read More »
Low hot water pressure crebive Plumbing 24 11-07-2009 09:55 PM
Water connections for new water heater diggerdave Plumbing 16 03-16-2009 12:36 PM
Water Heater Problems martyshel Electrical 4 01-24-2009 02:07 AM
Electric Water Heater GTSRider Plumbing 31 12-07-2008 01:30 PM
Water Heater tsmith Plumbing 10 12-01-2008 08:24 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
