HELP! Drain In Shower Too High - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-17-2013, 05:49 PM   #1
HELP! drain in shower too high
HELP! We are renovating a shower in a condo- top floor. the floor is concrete and the plumber just moved the existing bath tub drain about a foot from the wall and says he can't lower it any more than it is so we will have to raise the level w/ concrete and that will make the lip only 2&3/4" I just put the water shield membrane down HELP! drain in shower too high-pc170003.jpg We think there should be a way to lower the drain. Any suggestions???
uglymotherpluck is offline   Reply With Quote
Old 12-17-2013, 06:27 PM   #2
Rewards Points: 2,226
Can't tell from the picture; what size is that drain?? Tubs/shower combinations are usually 1-1/2. A standalone shower requires a 2-inch drain.
How much too high is the drain? Not sure if there's such a thing as a PVC street elbow, but if would sit a bit lower if there is one. Why did you put down the membrane before solving this problem?? Or am I misunderstanding what you said?
md2lgyk is online now   Reply With Quote
Old 12-17-2013, 07:18 PM   #3
we are just going to pile concrete to raise it cause we have to get this done.
Old 12-17-2013, 07:55 PM   #4
Rewards Points: 1,726
Do folks live below you? Should be a great insurance claim.
Old 12-18-2013, 05:53 AM   #5
DIY staff
Rewards Points: 3,280
Once again,showers require 2" drains---what kind of pan will you be using?
oh'mike is online now   Reply With Quote
Old 12-18-2013, 09:24 AM   #6
Very bad idea. Do it right or not at all. Especially if the property of others can be impacted.
Old 12-22-2013, 12:19 PM   #7
it is in concrete so no pan -we already tiled it cause the plumber and another construction worker said it would be fine- we own the unit below- it is a two story building. I hope to God that we are doing things right- I am about to have a nervous breakdown!!! We have to move in by Jan. 1st!
Old 12-22-2013, 02:28 PM   #8
DIY staff
I hope so to---concrete is not waterproof--water will soak right through it,given enough time.
Typically ,a concrete pan is covered with a waterproof membrane before the tile is installed---either a liquid /paint on like Hydroban---or a fabric cover like Schluter--
Old 12-22-2013, 05:59 PM   #9
Rewards Points: 2,604
what are you looking for ..your asking questions from pros and not listening at all...why ask.. ben sr
The Following User Says Thank You to ben's plumbing For This Useful Post:
oh'mike (12-22-2013)
Old 12-22-2013, 09:11 PM   #10
That's because the OP doesn't like the answers.
The Following 3 Users Say Thank You to md2lgyk For This Useful Post:
ben's plumbing (12-23-2013), Javiles (12-22-2013), oh'mike (12-22-2013)
Old 12-22-2013, 09:22 PM   #11
Master Plumber
Javiles's Avatar
Rewards Points: 718
Bad news pressure fitting not allowed you cant offset a trap. you cant reduce a drain line no shower pan, liner, etc, thats just what can be seen who knows whats below... looks like it was done by jack of all trades master of none.
Experience is Knowing what to do next, Skill is knowing how to do it
http://www.americandrain.net
Javiles is offline   Reply With Quote
The Following User Says Thank You to Javiles For This Useful Post:
Old 12-26-2013, 04:30 PM   #12
Thanks for the bad news - Oh well I guess I can just nag my husband and say" I told you so" as I sit in my padded cell!
Old 12-26-2013, 05:37 PM   #13
The absolute best way to get a husband to never do another project around the house is to nag him about it. In your case, that seems like a pretty good idea. But whatever you do, get him to stop working on that shower before he gets far enough to actually try to use it.
The Following User Says Thank You to md2lgyk For This Useful Post:
123pugsy (12-26-2013)
Tags
shower drain concrete
Shower drain venting issue gregoriep Plumbing 2 05-03-2013 06:50 PM
floor drain to shower drain? The Dogger Plumbing 4 01-30-2013 10:02 PM
Problem with shower pan and drain ohiogirl1965 Plumbing 1 06-07-2010 07:33 AM
Basement Shower Drain Problem! cleveland1980 Plumbing 16 01-29-2010 01:49 AM
Food backing into shower drain Manuel6 Plumbing 5 11-23-2006 09:59 AM
