Help Drain Near Shut Off Is Leaking A Lot Of Water - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-09-2012, 09:26 PM   #1
Help drain near shut off is leaking a lot of water
hi all, really need help. the drain near the main water shut off valve is leaking a lot of water when the valve is turned on, is this an easy fix? or do i need to call a plumber? i dont think i can afford a plumber right now
any help would be greatly appreciated. thank you!
neru is offline   Reply With Quote
Old 11-09-2012, 10:16 PM   #2
Plumber
TheEplumber's Avatar
Rewards Points: 440
Turn the main valve off- which I assume is the lower one in the picture. Remove the leaking valve using two pipe wrenches- 1 to unscrew and 1 as a back up wrench. Take the bad valve down to a hardware store for a replacement. Reassemble using teflon tape on the threads. Slowly turn the water back on and check for leaks
Old 11-09-2012, 10:18 PM   #3
the other valve you're talking about doesn't look like its a valve? its just some sort of a drain?
Old 11-10-2012, 07:23 AM   #4
Rewards Points: 1,560
The valve near the mulch looks like it is partially on. If you close that does the water coming out of the open pipe stop?
It does look like a drain line to me.
Where does that pipe go into the house? There may a valve on the other side of the wall to stop flow to that open end outside?
bob22 is offline   Reply With Quote
Old 11-10-2012, 08:46 AM   #5
Rewards Points: 13,256
Go back and add your location to your profile please.
I'm not even see where that valve would serve any purpose.
Even if it was opened water would stay in the line from underground up to that point and freeze.
Old 11-10-2012, 08:57 AM   #6
Rewards Points: 684
His location would be of no value but knowing how to re-size pictures sure would be .
Old 11-10-2012, 09:16 AM   #7
SO you think that if he lives above the mason dixon line it would be fine to have exposed PVC pipes with no way to drain them?
Old 11-10-2012, 10:39 AM   #8
Rewards Points: 684
Exposed pipes makes no difference at all since that wasn't the question.
Leaking Pipe above hot water heater with pics notarock Plumbing 9 07-30-2011 09:29 PM
Central Air Secondary Drain Leaking - 3 questions walters_12 HVAC 7 05-11-2011 04:20 PM
How do I drain my water heater? HVAC_NW Plumbing 10 11-10-2010 04:15 PM
Leaking water line needs new water regulator? huynh Plumbing 16 11-04-2010 12:32 PM
First time homeowner from MD - Water Leaking from Ceiling under bathroom j_cross Plumbing 2 02-27-2010 12:37 AM
