Help With Drain - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-05-2010, 12:33 AM   #1
Help with drain
I have attached a picture so you all can see what I am dealing with. The back wall where it is measured 25 inches is an outside wall. So I know I have to put drywall back up there, which I have taken the measurement minus the thickness of drywall. I am in a tri-level house so the plumbing comes from above. The part where you see I wrote coming out that is where the plumbing is now and is being moved. My problem is what base size should I get that will work. I know I might have to add to the wall on the left and the outside wall to make it thicker which is fine. I'm trying to find a base that will work. I do not want to tile, since that is what I took out. Any help and/or sites would be great. I was looking at getting a 34x42 shower, but dont know if that will work. Sorry about the lines not being perfect, I'm not great when it comes to drawing
southernmom is offline   Reply With Quote
Old 12-05-2010, 05:06 PM   #2
Rewards Points: 150
Most of the time the shower base goes to the stud line, but you can put it where you want. The problem seems to be that you are trying to get a base to fit your existing drain which is doubtful, you have to buy your base first and bust the concrete to get the drain to match, sorry.
braindead is offline   Reply With Quote
Old 12-05-2010, 05:52 PM   #3
Plumber
TheEplumber's Avatar
Rewards Points: 540
Yep, your exsisting drain assembly needs to come out if you're using a shower base. You will need a new drain assembly when setting the base. Move the trap and walls to match the new install
Slow and clogged shower drain help COBRA90GT Plumbing 9 12-22-2009 02:25 AM
Furnace leak while running AC unit lbartowski HVAC 3 09-18-2009 01:46 PM
Wierd Floor Drain "Backup" rawkintrevo Plumbing 9 06-04-2008 07:10 PM
The Bioswale, french drain, deck, drainage dilemma (long) seabright_sc Building & Construction 2 01-05-2008 03:37 PM
