Help: Distance From Upstairs Toilet Vent Stack To A New Downstairs 1/2 Bath - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-14-2010, 02:40 PM   #1
Mistakes make knowledge
help: distance from upstairs toilet vent stack to a new downstairs 1/2 bath
hello
I am writing this for information on wether or not I can just tie a 3 or 4 inch pvc pipe into my original stack from a new 1/2 bath I would like to put downstairs. The new bathroom woulc be about 20 feet away from the main vent stack and I do not want to try to run an aditional stack for this half bath. Can I tie this new toilet into my main drain, this drain comes from the bathroom upstairs where it is vented out the roof. thanks for any help .. i have attached a drawing of what i'm looking at ...
Heikks2002 is offline   Reply With Quote
Old 01-14-2010, 06:16 PM   #2
Originally Posted by Heikks2002 View Post
hello
Not sure what the code is in Michigan, but here in MA you could certainly tie your new waste pipe from the half bath into the waste stack that serves the upstairs bath, BUT you'd also have to run a new vent for the half bath. The new vent doesn't have to go through the roof independently (although it could if that's easier to do), but you could tie it into an existing vent a minimum of six inches above the flood-level rim of the tallest fixture on the floor above (e.g. - if the highest "flood-level rim" is a the rim of a sink basin that's 36" tall, you can tie the new vent into the existing vent at 42").
AAV's (Air Admittance Valves - aka: mechanical vents) are prohibited in MA except in extreme circumstances, but maybe they're allowed there? You'd have to check with your local code enforcement official(s).
Ishmael is offline   Reply With Quote
Old 01-15-2010, 09:17 AM   #3
Rewards Points: 3,130
Of course you can do it, but the specifics of what you have to do depend on the applicable code. The Uniform Plumbing Code and the International Residential Code handle venting very differently. You need to talk to your local inspector.
Old 01-15-2010, 10:21 AM   #4
thank you for your help, very appreciative. It def gives me a road to go down and figure this all out. again thanks
Toilet jpark Plumbing 18 01-05-2009 07:12 AM
finishing a basement bath - tie in to ejector pump vent? ajbowman Plumbing 7 04-15-2008 12:09 AM
Can I tie the sink vent into the toilet vent? domgbrown Plumbing 4 01-11-2008 05:28 PM
Upstairs toilet pipe noise bliss Plumbing 8 01-10-2008 07:55 AM
DWV Stack Question dcgray2 Plumbing 9 07-14-2006 12:56 PM
