Old 09-20-2008, 04:15 PM   #1
Help Dishwasher Draining Problem
The majority of water from the dishwasher is draining from the overflow spout into the sink and water is draining down back wall and around sink back underneath sink. I removed the pipe 7/8" dishwasher drain pipe from green Y, pipe connected to dishwasher to determine if there was a stoppage. It needs to be cleaned but it was not clogged. It did not use to backup like this. The overflow on topside has so much water coming out that it gets all over the counter and leaks back down to all cabinets and onto floor. I need an idea how to reroute.
Help Dishwasher Draining Problem-plumbing-001.jpg   Help Dishwasher Draining Problem-plumbing-002.jpg
swicks15 is offline   Reply With Quote
Old 09-21-2008, 10:00 AM   #2
I'm not sure about the connections but if its backing up into the sink, and it didn't use to, I'd say there is a clog somewhere in the drain pipe, you might be able to check it out further down the line.
DUDE! is offline   Reply With Quote
Old 09-21-2008, 01:58 PM   #3
I agree with Dude. It is a blockage in the sink drain pipe. You would not notice it so much while draining the sink, but the pump on the DW has much more volume. Also check where it connects to the disposal.
If you have never made a mistake, you haven't done much.
majakdragon is offline   Reply With Quote
Portable Dishwasher problem canadaclub Appliances 5 06-04-2009 06:42 AM
Kenmore Dishwasher Rinse Aid Draining Tate71 Plumbing 7 07-30-2008 10:41 AM
Stymied by window leakage problem. Matth3w General Discussion 5 06-11-2008 07:26 PM
Kenmore Ultra Wash Dishwasher mystery rtyui2 Appliances 3 05-29-2008 11:35 AM
Dishwasher placement jkrodger Remodeling 2 08-03-2007 03:32 PM
