Old 12-01-2008, 06:21 AM   #1
HELP!! ... Combi boiler.
Hi, I have a huge problem with our Worcester Combi boiler. I have bled the radiators & the pressure in the combi was low so I just turned the valve to increase pressure, and then turned it shut once done.
But now the pressure just keeps going up and up until the relief valve kicks in!! .. I tried relieving the pressure by opening a radiator valve, this takes it down ok, but then it just starts racing up again!!!
Any idea's what the cause could be and how to remedy it? .. The wife's in bits
pebo is offline   Reply With Quote
Old 12-01-2008, 09:35 AM   #2
Master General ReEngineer
Ayuh,... It sounds like it Didn't shut Off...
Is there a Bladder Tank,..?? It might be Waterlogged...
Old 12-01-2008, 10:31 AM   #3
Sorry but I have never heard of a bladder tank.
More On This Topic
Anyone living with large, steaming hot radiators in their home will eventually think of replacing them with something smaller and cooler. A simple solution is to replace your radiator with a smaller, less sizable convector. Here are the steps to replace... Read More »
Hi! I'm John Brown from High Road Cycles in Wayne, Pennsylvania on behalf of Expert Village. Today we are going to learn about proper tire inflation. To start the first thing and most importantly, is to figure out what pressure your tire should be at... Read More »
Hello, I'm Mark Blocker with Expert Village. In this segment were going to cover the heating and cooling system. In many of today?s new automobiles they have an air bypass valve installed on the cooling system. As I described before there is a thermostat... Read More »
Hi this is Jeff Wong with Expert Village and today we're going to learn the basics of maintaining your vehicle. Next we're going to check the engine coolant. I want to warn you here that engine coolant can be very hot if your car has been recently... Read More »
In this segment, we're going to cover draining the radiator. Prior to draining the coolant out, first thing we need to do is remove the cap. If the system is under pressure, when you push down on this cap to release it, in order to turn the cap, it's got... Read More »
Circulation pump on boiler uncleneiler Plumbing 2 05-09-2008 10:59 PM
Boiler Shut Down SassySue General Discussion 3 01-01-2008 12:49 PM
Boiler Options -Will Boiler be good enough??!! deano54321 Plumbing 2 10-28-2007 07:18 PM
Steam boiler corrosion problem franklopes HVAC 4 11-09-2006 09:02 PM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
