Help, Cannot Find Correct Tub Drain Stopper - Plumbing - DIY Home Improvement | DIYChatroom
Like Tree2Likes
  • 1 Post By Bud Cline
  • 1 Post By ryanmw2002
Old 08-13-2011, 12:25 PM   #1
Help, Cannot find correct tub drain stopper
I have a Kohler tub that was probably original to the house which was built in 1984.
The stopper linkage has seized up and can no longer pop up the stopper to fill tub. There is basically no access to the pipes. The plumber recommended installing a toe touch or lift and turn stopper in the drain.
I have gone through 5 different drains (all lift and turn) and none of them will screw back into the original tub shoe assembly.
I have tried 1 3/8" fine thread, 1 1/2" course thread, 1 1/2" fine thread. The original drain is course thread and appears to be 11.5 threads per inch.
I measured the diameter of the original drain screw and it measures a little over 1 1/2" on outside diameter of screw, and a little over 1 3/8" inside diameter of the screw. The height of the screw is about 1" tall when measuring from top of screw to bottom of screw, and 1 1/4" tall when measuring from flange to bottom of screw.
I have logged about 16 hours online researching and still cannot find a replacement. Does anyone know of a drain that matches those dimensions?
Thanks!
ryanmw2002 is offline   Reply With Quote
Old 08-13-2011, 02:20 PM   #2
Rewards Points: 14
just a suggestion
I'm in this forum looking for advice, myself. But, I read your post. I might suggest calling Kohler Customer Service. Companies that have been around as long as they have usually should be able to help. Good luck.
papernpaste is offline   Reply With Quote
Old 08-13-2011, 05:05 PM   #3
Tileguy
Bud Cline's Avatar
Rewards Points: 558
So.....What's the plumber say about all this?
Is he really a plumber and if so, why can't he fix it?
SHR Plumber likes this.
XXX
Old 08-13-2011, 06:18 PM   #4
I called Kohler's contact number and it directed me to a customer service rep who could not help but gave me a phone number of another department however they dont open until Monday.
The plumber actually did not take out and replace the assembly because they were there under another service call (home warranty service call for a separate issue). The drains they had would not fit and suggested a plumbing supply company but they dont open until Monday either.
I really have a feeling that this drain is no longer made and will be not worth my time and energy to track down.
I have ordered a NuFit universal stopper and plan to just leave the original drain in. Hopefully this will work and can finally call it a day.
Old 08-13-2011, 07:51 PM   #5
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Ace Hardware sells corks.
XXX
Old 08-13-2011, 08:39 PM   #6
Unfortunately i couldn't even cork it if I wanted to! the crossbars are at the top so cant even use some cheap rubber stopper...
My next option was to send it to hollywood to have special effects team make cast of the threads and then have blacksmith pour 24k gold into it, creating my new drain and lift & turn stopper ....probably would have been cheaper and less time consuming than the BS ive gone through so far.
Ghostmaker likes this.
Old 08-13-2011, 11:43 PM   #7
Tileguy
Bud Cline's Avatar
Rewards Points: 558
HOLD ON !!! RED FLAG !!!
Have you been removing the piece with the "cross bars" when attempting to install one of the new fixtures?
The problems you are having aren't making any sense to me. I have done what you are trying to do scores of times over the years and never had a major issue. The replacement drain fixtures do come in more than one size but most of them I have seen come with more than one size bushing also for that reason. What are we missing here?
XXX
Old 08-14-2011, 01:22 AM   #8
Yes, the drain has a crossbar near top (just below flange) with hole in middle. Also there is a flat strainer with a hole in middle that sits on top of the drain, a screw is then inserted into both strainer and drain to push strainer tight to drain.
I have removed screw, strainer, and drain (drain was removed using cloth covered plyers down inside the drain and turning against crossbars)
i havnt found a single replacement drain that will fit and/or screw in all the way.
The ones that fit (im assuming 1-3/8") will not screw in all the way. It seizes about 3/4 of way. I'm assuming this is because they are 16 TPI fine thread and my old drain is 11.5 TPI coarse thread.
They usually come with 1-1/2" bushing that is also coarse thread, but with bushing on it will not fit in the hole.
I assume I need a 1-3/8", 11.5 TPI coarse thread drain which does not appear to be manufactured by an living individual and/or all existing drains of this size were melted down in WWII for ammunition, except of course the one that resides in my tub.
The Following User Says Thank You to ryanmw2002 For This Useful Post:
Bud Cline (08-14-2011)
Old 10-21-2011, 10:15 PM   #9
Rewards Points: 47
I'm experincing the exactly problem. How did you resolve this?
tate16t is offline   Reply With Quote
Old 10-21-2011, 11:09 PM   #10
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Now re-read that comment tate16t, and tell me what you think of it.
Old 10-22-2011, 08:58 AM   #11
Rewards Points: 47
I have re-read the comment. I still have the same problem. It seems the threads are different and the new stopper will not screw in. It goes in part of the way and stops.
I'm going to try the Flip It Universal Tub Stopper.
Let me know what you think.
Old 10-02-2016, 04:29 PM   #12
Rewards Points: 2
Re: Help, Cannot find correct tub drain stopper
Just had to say , I know its way old post but u I understand completely this guys problem. Because I have the same issue, the actual drain pipe is not deep enough to accommodate any new style tub drain. It simply bottoms out while screwing it in, all drains I see have way too many threads....WHY.....WHY.....WHY.........
bmf916 is offline   Reply With Quote
Old 10-03-2016, 08:24 AM   #13
Rewards Points: 320
My 70's? kohler also has shallow drain assembly. It has a rocker type stopper operator and I am thinking it never drained quickly and according to just a few I've seen, the owners removed the stopper. The stopper/rocker doesn't lift high enough and is a hair trap.
Reading this old post made me think that kohler had one casting mold for all bath drains and just added minor details for different styles. Kohler also discontinues unprofitable replacement parts. Kohler or other brands, I would not use such drain/stopper. I still prefer the screw on strainer for hair and plunge barrel type stopper.
For difficult drain like this post, I'd try flange adapter (amazon) and as long as fits into the hole, cut out the parts that won't fit. Epoxy in and use cork type stopper on stainless chain.
Remove the cross hairs with dremel.
carpdad is offline   Reply With Quote
Where to find correct polyurethane caulk for foundation cold joint? mikegp Building & Construction 4 07-17-2011 06:22 PM
Bathtub Drain -- Without Overflow Waste Trap sabinh Plumbing 6 02-15-2010 11:24 AM
Furnace leak while running AC unit lbartowski HVAC 3 09-18-2009 02:46 PM
Sink Drain Stopper Won't Pop Up erclark Plumbing 7 07-11-2009 08:31 AM
Where to find 2" square plastic drain pipes The_Flash Roofing/Siding 4 07-25-2005 08:35 AM
