HELP! Broken Shower Drain Connection To ABS Trap - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-22-2012, 04:15 PM   #31
Rewards Points: 582
Originally Posted by megablok View Post
Back to the store to get ABS fittings and ABS cement.
hey guy why not slow down look at the whole picture here many people telling you alot of things to do ....think about what you are doing you have figured out a way to get your project done ....do it ....all this information is great in the right setting sometimes we don't get the right setting....then we make the best of it ...as long as its close to being right...your as close as you are going to get WITHOUT CUTTING IT ALL OUT...its your call.....ben
Old 04-22-2012, 04:19 PM   #32
Plumber
TheEplumber's Avatar
Rewards Points: 792
Originally Posted by ben's plumbing View Post
yes ..it tends to fail ..so they say....again look at the thread as to what is happening.....the op won't cut it all out and start from scratch.....so 30 yrs in the trade never seen pvc glue on abs fail... he won't find abs drain like that he don't have height to use adapter if I read right......so what to do ....use the pvc glue get er done......move on.... it will work on that joint and hold......
Ben, I agree with you except one point- ABS drains are a dime a dozen in my town so using PVC glue as a transition glue wouldn't be considered, but I've done it for 3034 sewer line to ABS building drain connections
Old 04-22-2012, 08:13 PM   #33
Rewards Points: 582
ok I agree ..if you can find abs drain ..most are pvc.....and yes using the glue is not the best..but if a home owner is going to mix abs and pvc...use the pvc glue....thanks
Reusing existing drain frahms_4 Plumbing 19 12-30-2011 02:27 PM
I have a floor drain that does not line up with the shower stall and there is no trap. Daddy6h Plumbing 2 11-02-2011 09:42 AM
Help with upstairs shower drain davesconzeuntry Plumbing 3 08-28-2011 06:19 PM
Shower to Tub; using the original drain? recmhb Plumbing 0 08-01-2011 10:07 AM
Problem with shower pan and drain ohiogirl1965 Plumbing 1 06-07-2010 06:33 AM
