HELP! Broken Shower Drain Connection To ABS Trap - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-16-2012, 04:30 PM   #1
HELP! Broken Shower drain connection to ABS Trap
We removed a sunken tub and installed a shower drain. The trap for the drain was 2" with a 1.5" reducer glued into it with a male thread sticking up.
We hooked up a 2" shower drain to it, however, while attempting to level the floor, the connection broke right at the base of the 1.5" male threaded adapter.
The trap is now under the ground below the slab and attached to the main drain somewhere under the slab in the soil.
How to repair this?
Help!
Im trying to upload an image, but it doesnt work......
megablok is offline   Reply With Quote
Old 04-16-2012, 05:34 PM   #2
Rewards Points: 636
are you able to show pic yet
"be careful at listening to just one persons advise" said me
"be careful at listening to just one persons advise" said myself
p.s. not all i say is a fact but not all i say is my opinion.
jaydevries is offline   Reply With Quote
Old 04-16-2012, 06:40 PM   #3
I choose upload image but, the pop-up screen goes blank trying to upload and never recovers.....
aargh
Old 04-16-2012, 07:58 PM   #4
Rewards Points: 582
bang bang bang went the hammer
Old 04-16-2012, 09:19 PM   #5
Plumber
TheEplumber's Avatar
Rewards Points: 664
How to repair this?
Help!
Cut out the slap and rebuild the drain-- only way
The Following User Says Thank You to TheEplumber For This Useful Post:
VIPlumber (04-16-2012)
Old 04-16-2012, 09:26 PM   #6
JDC
Plumbing Contractor
JDC's Avatar
Rewards Points: 262
Hate to be the bearer of bad news but it sounds like it's jackhammer time.
Good luck and keep up posted
JDC is offline   Reply With Quote
The Following User Says Thank You to JDC For This Useful Post:
Old 04-17-2012, 10:17 AM   #7
The Trap is 2" with a 1.5" adapter glued into it. I was able to cut it nicely with a dremel along the top of the trap and remove the adapter.
Is it possible to glue on a 90-elbow 3" on the 2" trap?
Maybe then I could turn it with another 3" 90-elbow to a 3" shower drain.
Here is the picture.
Old 04-17-2012, 12:45 PM   #8
Plumber
Rewards Points: 664
You might have to remove more concrete but the best fix is to cut behind the trap and extend the horizontal trap arm to where the ptrap needs to be. Then you can glue the drain right on top of the trap.
Using 3" 90's is a bad idea.
Old 04-17-2012, 02:01 PM   #9
Rewards Points: 1,580
That slab looks about 15 mins of a good wacking with a sledge hammer to get what you need. Go for it! Use your anger!
bob22 is offline   Reply With Quote
Old 04-18-2012, 09:51 PM   #10
More Problems. The trap is connected to the following:
Trap - Street 90 - Tee
The Tee has a vent pipe above it, and a Street Elbow below it. I cannot get to this street elbow because it is below the foundation slab.
I have a schematic showing the problem.
HELP!
Old 04-19-2012, 12:13 AM   #11
Rewards Points: 636
use one off these at the t to remove street 90 will cost around $30
http://www.pascospecialty.com/catalo..._CATALOG_C.pdf
Old 04-19-2012, 08:11 AM   #12
Thanks so much Jaydevries. We are trying to find that tool in Houston, TX. Will post updates soon.
Old 04-19-2012, 04:21 PM   #13
We found the tool and drilled out the male adapter from the p-trap. However, I am a bit concerned that the hub wall thickness may now be too thin and could potentially break.
It measures 3.90mm at the thinnest point. At the same time, it is very difficult to drill out the street elbow from the Tee. We are no sure what is behind the street elbow under the Tee either.
ASTM D2661 says that the nominal thickness of ABS 2" is 0.154 inches which is 3.9mm - exactly that it measures on the hub.
I want to install a street elbow 90 on the P-trap, extend with a pipe and another street 90 to connect to new shower drain. Is that a recommended configuration?
Old 04-19-2012, 08:15 PM   #14
Rewards Points: 636
no that is not correct the trap should be moved so it is under shower drain then a piece of pipe to go straight up into shower drain, this way shower drains correctly and also if ever clogged. a drain snake can be ran through pipe. also you should fill hole back in with dirt to cover trap then add at least 3 inches of concrete leaving 6 inch hole with shower pipe in center of hole. so the bottom of shower is solid around drain. if it is a fiberglass shower read install instructions most recommend setting pan in mortar to firm up bottom and to level, this will also help so shower pan does not crack after a few years of use
also the cut out tool make sure you have correct guide washer for abs. try to keep cutter straight after cutting out pipe sand inside of fitting then use plenty of glue on pipe and inside of fitting so when pipe is pushed into fitting there is a pool of glue around pipe
Old 04-19-2012, 08:20 PM   #15
Rewards Points: 582
I would not install that way ...move trap to under center of shower...
Reusing existing drain frahms_4 Plumbing 19 12-30-2011 02:27 PM
I have a floor drain that does not line up with the shower stall and there is no trap. Daddy6h Plumbing 2 11-02-2011 09:42 AM
Help with upstairs shower drain davesconzeuntry Plumbing 3 08-28-2011 06:19 PM
Shower to Tub; using the original drain? recmhb Plumbing 0 08-01-2011 10:07 AM
Problem with shower pan and drain ohiogirl1965 Plumbing 1 06-07-2010 06:33 AM
