HELP!! Bathtub Overflow Cover Fell Off. Need To Fix. - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-05-2010, 01:47 PM   #1
Question
HELP!! Bathtub Overflow Cover Fell Off. Need to fix.
Hey everyone.
Recently while cleaning my bathroom the screws connecting the overflow cover on the tub broke.
There are still screw holding the pipe to the tub (pipes are brass) and I think I can get them out to replace the screws and put the cover back on.
I have been reading and I hear there is a gaket I need but I did not see one when the cover fell off.
Can I just replace the screws with similar sized screws and put the old cover back on?
Is there a special gasket I need for Brass pipes?
Is there any caulk I or putty I need for this job.
Thanks so much everyone!
Mac Danny is offline   Reply With Quote
Old 08-05-2010, 01:53 PM   #2
Originally Posted by Mac Danny View Post
Hey everyone.
Additionally, I have a bag over it now until it is fixed but I never had a leak problem so i don't think the gasket is bad.
We have never used the tub as a tub though.
Old 08-05-2010, 02:05 PM   #3
Handyman
Rewards Points: 512
You shouldn't have to replace those screws. In fact its best if you leave them alone and just buy a new cover. The gasket you refer to is between the brass pipe and the tub. Unless its leaking, I wouldn't touch it.
Oh yeah, and you should not require caulking if the gasket is sealed good.
canadaclub is offline   Reply With Quote
Old 08-05-2010, 02:07 PM   #4
The head of the screws rusted out and sheered from the body of the screw.
I think there is enough screw left to get them out.
Old 08-05-2010, 02:24 PM   #5
Owner
LateralConcepts's Avatar
The screws don't hold the pipe to the tub without the cover plate in place.
Because they're usually worlds longest screws, you should have a 1/2" or so sticking out the back. If it's accessible, you can turn them from the other side. Once they're out, you can buy a new universal cover plate that should come with screws and a foam gasket.
Brad Penske, Operations Manager - Coeur d'Alene, ID
Lateral
CONCEPTS, LLC - Sewer & Septic Line - Video Inspection, Locating, Consulting
(208) 818-8241
Like us on Facebook!
LateralConcepts is offline   Reply With Quote
Old 08-05-2010, 02:32 PM   #6
Thanks!
Can I just get the screws? the old cover plate had the pull up stopper and I am not sure if I can get it out.
So right now the overflow pipe is not attached to my tub. That's frightening. Thank god for duct tape and plastic wrap.
Old 08-05-2010, 04:16 PM   #7
Retired Plumbing Cont.
Once you get the old screws out, take one down to the hardware store and match the diameter and threads to the ones you need.
rockerjockey is offline   Reply With Quote
bathtub overflow drain not lining up plumbernewbie Plumbing 6 09-18-2010 05:34 PM
Bathtub Drain -- Without Overflow Waste Trap sabinh Plumbing 6 02-15-2010 10:24 AM
Bathtub Tile Lip Cover Imanewb Kitchen & Bath Remodeling 1 05-17-2009 10:47 PM
Washer agitator/spinner turns one way, but not the other IckesTheSane Appliances 5 01-10-2009 02:53 AM
Help with Overflow Drain Kit for Bathtub ... njchan Plumbing 1 01-08-2008 11:32 PM
