Old 10-30-2009, 10:24 PM   #1
Default Help With Bathtub Dimensions...
I'm currently remodelling my bathroom completely and have stumbled into a big problem - finding a bathtub with proper dimensions (or so I think) and need some help.
My former bathtub had dimensions 60" x 30" x 16".
My contractor bought one with correct length and width but height of 14". The 60" end against the wall rests against a horizontal wooden beam (16" from the ground), so the tub is at an angle because the front sits on its base and is 14" from the ground to the top.
The contractor wanted to put 2x4"s under the tub to level it completely at 16" from the ground to the top of the tub. I wasn't too big on the idea to begin with, but I [don't know how neither of us] noticed the warranty sticker that voids the warranty if any materials are placed under the tub for support. The contractor has left for the night so I can't ask him questions at the moment and I'm hoping to find a solution before meeting tomorrow morning.
So...
Do I have to adhere to 30" width? I'm guessing that a 32" would not align with my drainage. Most importantly, do I have to stick to the 16" height? It is almost impossible to find a 16" tall bathtub on any of the major manufactorer's Web sites.
Thanks in advance!
Jamaro85 is offline   Reply With Quote
Old 10-31-2009, 08:10 AM   #2
60" is the standard length for tubs, width and height may vary. Height is generally not an issue since you have to remove tile/drywall anyhow. Filling in a floor can be accomplished with adding a tile border, or if vinyl, a new floor. Cutting out a tile floor needs a masonary or diamond saw. All of these things are normal and usual when remodeling.
Old 10-31-2009, 08:19 AM   #3
Is it possible to just build up the whole area under the tub 2"?
Plumbvoltage is offline   Reply With Quote
Old 11-02-2009, 11:48 AM   #4
Default Problem Resolved
Thanks for the responses! I've decided to let the contractors install supporting 2x4 beams underneath and not worry about the warranty. Bathtubs are not all that expensive anyway and this seems to be the only solution out of convenience. They have done a good job at getting it done and covered the two inches of wood with cuts of the matching marble floor tiles.
All is good now, thanks again.
Tags
bathtub dimensions
More On This Topic
Although today we're not actually going to build the container for a raised bed garden, there are a few things you might want to consider if you don't have a ready made container like we have. I've seen raised beds made out cross ties, tuba sixes, just... Read More »
Bathtubs can be dangerous places for those with disabilities. It's important to lay out the bathtub area carefully to provide optimum safety. Depending on your budget and space, there are a variety of modifications that can be made to help insure a safer... Read More »
When the time comes to remodel your home don't take on a project that you can't handle. With jobs that require specific skills that you don't have hire a general contractor. Follow these easy steps to hire a general contractor. Read More »
If you're owned by a cat, there's probably several new kitty toys lying around your house, all advertised to be the one your feline can't do without. The truth is, cats can do without almost any toy, but if you must buy a toy for your cat, the top ten... Read More »
I'm Betty Ingham speaking on behalf of Expert Village, that we wanted to show off this beautiful old bathtub. Luckily inside the tub was good enough that we didn't have to do anything inside of the tub. We ordered this old fashioned looking shower head... Read More »
Bathtub Drain -- Without Overflow Waste Trap sabinh Plumbing 5 04-20-2009 11:37 PM
Floor load w/ bathtub DSKUP Building & Construction 5 12-30-2008 12:07 PM
need to convert a bathtub into a shower q5485 Plumbing 9 11-30-2008 11:39 PM
Preparing to install Kerdi on bathtub surround DIY-Renovator Flooring 18 07-17-2008 12:42 PM
Help with ID'ing bathtub sound... DIY-Gal Plumbing 12 02-10-2007 07:45 AM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
