Originally Posted by e in br
We have a sink that is stopped up. Drain-0 hasn't worked so my husband did the snake cable some twenty feet and nothing. Still stopped up. How can you tell if the cable is going up the vent instead of down the drain pipe? Don't want to have to call out the professionals. Thanks.
Once you get rid of the drain cleaner from the sink (shopvac), you need take the trap apart, and either clean it or replace it. Chances are good that the clog is either in the trap or junk clogged on the stopper or both. Once the trap is out, it is easy to see both. Keep in mind the trap will be filled with the drain cleaner that is caustic.
There is a possibility that there is a clog further down the line, but if that is the case, you really need to run a power reamer down the drain or replace it.
What kind of material is the trap made out of? If it's not PVC, I would replace it with PVC.
Good Luck
Jamie
