Help With Basement Rough-in Identification - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-25-2013, 07:30 PM   #1
Help with basement rough-in identification
I have looked at most of the pictures in this forum and am not in a position to identify what these pipes are for. The most confusing one is the one with a cover titled 'SEWER', what is that for and why is it even there?
arsh14 is offline   Reply With Quote
Old 02-25-2013, 07:53 PM   #2
Plumber
TheEplumber's Avatar
Rewards Points: 556
Open the sewer lid- what do you see? It's probably a backwater valve.
The 3" is your toilet.
Old 02-25-2013, 07:55 PM   #3
Rewards Points: 636
could be a sewer backwater valve or sewer clean out. take cover off and see what is there
"be careful at listening to just one persons advise" said me
"be careful at listening to just one persons advise" said myself
p.s. not all i say is a fact but not all i say is my opinion.
jaydevries is offline   Reply With Quote
Old 02-26-2013, 07:00 AM   #4
What is a 'backwater valve'? I opened it and found a lot of stones in it. Do I cover this with flooring when I finish the Bath?
I assume the one pipe on the far left is for the sink, the bigger pipe is for the Toilet and the one in the right is for the Tub. Is this right?
Old 02-26-2013, 09:08 AM   #5
Plumber
Rewards Points: 556
Did you remove the stones? The box is there for a reason. You need to clean it out.
Old 02-26-2013, 09:17 AM   #6
Roofmaster
Rewards Points: 2,172
You are building the walls on top of the drycore? Hmmmmmm.
Rough in for Basement TBolt Plumbing 8 12-13-2011 05:56 PM
New rough opening to basement - spiral staircase benjamincall Building & Construction 8 07-16-2010 05:53 PM
Basement wall issues. Need rough idead of fix. meltdowndave Building & Construction 6 10-03-2009 11:24 AM
Basement bathroom rough in plumbing ferris13 Plumbing 5 09-28-2009 10:06 AM
Best way to clean rough basement concrete floor Red Squirrel Flooring 3 09-21-2009 06:47 AM
