HELP ASAP Relocating Shower Drain In Slab - Drain Pipe Loose - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-20-2010, 02:00 PM   #1
Hello All,
I broke out the concret to the dirt. The old galvanized steel pip broke/cracked while trying to cut it down for new elbow. While working on it, I notice this pipe being loose. I dug down to where it connects to another vertical pipe. It seems to be connected somehow, but at the same time, it turns a little AND moves vertically a little. I also see a little moisture at the connection. My question is: Does this need to be replaced? Is it supposed to be loos or have movement? Really need help fast. Thanks.
perryj is offline   Reply With Quote
Old 08-20-2010, 07:07 PM   #2
Plumber
TheEplumber's Avatar
Rewards Points: 904
Yes, it needs to be replaced.
No, if its older galvanized pipe it should not move. The threads have probably rusted through.
Is all the pipe underslab and exposed?
Old 08-20-2010, 07:39 PM   #3
Yes, it is. I've cleared alot of dirt but not enough to expose the trap and lead to the stack/sewer. Will the loose piece unscrew? If so, I guess I could inspect the threads (if they exist) on the connection and maybe replace the one that's loose? Or, as I've seen online, should I expose the line, and maybe cut off the trap aswell, and run a new line, interface to the old pipe going to the stack/sewer?
I really appreciate the knowledge. Thank you.
Old 08-20-2010, 08:27 PM   #4
Plumber
Rewards Points: 904
I'm having a hard time picturing your piping. Can you upload a picture?
Any loose joints need to be examined and repaired/replaced. Sounds like you may have a lead and oakum joint thats loose.
Old 08-20-2010, 08:45 PM   #5
Yes. From what Im reading here and pics I see.
Old 08-20-2010, 08:48 PM   #6
Worst F'ing week. No I cant get the pics up. Not working all-the-sudden.
Very Strange Shower Drain Problem MattWhite Plumbing 12 05-21-2011 11:53 AM
protruding shower drain and supply pipe mooseofplenty Plumbing 2 07-21-2010 11:45 PM
Shower Pan and concrete slab plumbing LTempleton Kitchen & Bath Remodeling 2 08-08-2009 12:47 PM
Major drain issue... what is this pipe? moneymgmt Plumbing 9 08-04-2009 10:53 PM
Can I connect toilet drain to this drain pipe james739 Plumbing 11 04-24-2009 07:06 AM
