Help - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-07-2007, 07:09 PM   #16
my mother lives in the basement apt of this house, is there any way she could have accidently turned it off, she isnt home at the moment,,,troy just said there is no water at the bleeder
TROYMAC is offline   Reply With Quote
Old 03-07-2007, 07:10 PM   #17
Journeyman Plumber
Ron The Plumber's Avatar
Then you will need to turn hot water off at water heater and remove the shutoff valve and check for blockage there.
Fix it right the first time, so you won't have to fix it a 2nd time.
2008 Oregon Specialty Plumbing Codes
Ron The Plumber is offline   Reply With Quote
Old 03-07-2007, 07:12 PM   #18
Journeyman Plumber
Could be the case if there is a shutoff going to the sink only, thats way I asked about other fixtures having hot water flow.
Old 03-07-2007, 07:12 PM   #19
wouldnt that effect the whole house, we have 2 bathrooms and 2 kitchens and no problems anywhere but our upstairs kitchen sink. when he took the bleeder cap off it trickled a bit
Old 03-07-2007, 07:13 PM   #20
Journeyman Plumber
Replace the shut off under the sink.
Old 03-07-2007, 07:14 PM   #21
there is a shut off value on each fixture in the house...could this be freezing...wouldnt the cold be frozen too then?
Old 03-07-2007, 07:15 PM   #22
Journeyman Plumber
Is it real cold there? use a hair dryer to thaw the pipe if frozen
Old 03-07-2007, 07:15 PM   #23
so u think the shut off value could be the prob,,,do they clog or just break
Old 03-07-2007, 07:16 PM   #24
Journeyman Plumber
What type of pipes are there in the house?
Old 03-07-2007, 07:16 PM   #25
the temp went down to -30 windchill today but the pipes are inside the outer wall and the gyprock where should we be putting the hair dryer?
Old 03-07-2007, 07:16 PM   #26
copper
Old 03-07-2007, 07:17 PM   #27
Journeyman Plumber
Heat it up under the sink. leave water on so you know when it gets thawed out.
Old 03-07-2007, 07:28 PM   #28
we are going to see if the pipes thaw over nite, we cant get at the pipes to thaw with the hairdryer...thanks so much for all your help i will post again when we have hot water in the kitchen. for now we have to start boiling water for dishes...thanks again
Old 03-08-2007, 05:13 AM   #29
update, woke up this morning now the cold side isnt working. have been using hairdryers all morning, have trickle thru both cold and hot. just called a plumber in...will update again when i know something...thanks again for all your help
Old 03-08-2007, 09:27 AM   #30
Did your mother turn her heat down while she has been gone?
redline is offline   Reply With Quote
