Help - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-07-2007, 07:51 PM   #1
Help
my hot water kitchen tap just stopped working, bought new taps still doesnt work help any ideas?
TROYMAC is offline   Reply With Quote
Old 03-07-2007, 07:53 PM   #2
Journeyman Plumber
Ron The Plumber's Avatar
Does cold side work?
Fix it right the first time, so you won't have to fix it a 2nd time.
2008 Oregon Specialty Plumbing Codes
Ron The Plumber is offline   Reply With Quote
Old 03-07-2007, 07:54 PM   #3
yeah it does
Old 03-07-2007, 07:57 PM   #4
Journeyman Plumber
Make sure it's turned on under sink, if ok there, turn it off, take supply off at faucet, point it into a bucket, turn it on, and see if if you have flow through it. if so then it's in the faucet stem.
What brand is the faucet?
Old 03-07-2007, 07:59 PM   #5
new and old faucet are moen, ok we are doing what u said right now be right back
Old 03-07-2007, 08:00 PM   #6
what is the next step if you dont have flow when u turn it back on?
Old 03-07-2007, 08:02 PM   #7
no water at all
Old 03-07-2007, 08:03 PM   #8
Journeyman Plumber
Then if no flow through supply line, the shut off could be plugged up.
Old 03-07-2007, 08:04 PM   #9
Journeyman Plumber
Remove supply on shutoff and see if it's plugged up. Do you have hot water to other taps?
Old 03-07-2007, 08:04 PM   #10
the value has a bleeder can it be tested that way? no water flow at all when disconnected from taps
Old 03-07-2007, 08:05 PM   #11
Journeyman Plumber
Remove supply and check it.
Old 03-07-2007, 08:05 PM   #12
have hot water to all other taps, only kitchen tap
Old 03-07-2007, 08:06 PM   #13
supply line is clear from value to tap
Old 03-07-2007, 08:07 PM   #14
Journeyman Plumber
Then it's at the shut off valve try bleeder is there flow there.
Old 03-07-2007, 08:08 PM   #15
checking now, if no water at bleeder then what?
