-   -   Help (http://www.diychatroom.com/f7/help-6953/)
TROYMAC 03-07-2007 07:51 PM
Help
my hot water kitchen tap just stopped working, bought new taps still doesnt work help any ideas?
Ron The Plumber 03-07-2007 07:53 PM
Does cold side work?
TROYMAC 03-07-2007 07:54 PM
yeah it does
Ron The Plumber 03-07-2007 07:57 PM
Make sure it's turned on under sink, if ok there, turn it off, take supply off at faucet, point it into a bucket, turn it on, and see if if you have flow through it. if so then it's in the faucet stem.
What brand is the faucet?
TROYMAC 03-07-2007 07:59 PM
new and old faucet are moen, ok we are doing what u said right now be right back
TROYMAC 03-07-2007 08:00 PM
what is the next step if you dont have flow when u turn it back on?
TROYMAC 03-07-2007 08:02 PM
no water at all
Ron The Plumber 03-07-2007 08:03 PM
Then if no flow through supply line, the shut off could be plugged up.
Ron The Plumber 03-07-2007 08:04 PM
Remove supply on shutoff and see if it's plugged up. Do you have hot water to other taps?
TROYMAC 03-07-2007 08:04 PM
the value has a bleeder can it be tested that way? no water flow at all when disconnected from taps
Ron The Plumber 03-07-2007 08:05 PM
Remove supply and check it.
TROYMAC 03-07-2007 08:05 PM
have hot water to all other taps, only kitchen tap
TROYMAC 03-07-2007 08:06 PM
supply line is clear from value to tap
Ron The Plumber 03-07-2007 08:07 PM
Then it's at the shut off valve try bleeder is there flow there.
TROYMAC 03-07-2007 08:08 PM
checking now, if no water at bleeder then what?
