Height Of Sink Drain Connection - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-16-2010, 09:10 PM   #1
Rewards Points: 101
Height of sink drain connection
What is the maximum height to install the trap connection coming out of the wall for a laundry tub/slop sink. I'm limited to how low the piping can be in the wall. A few tubs I have seen have the bottom of the tub at 19", was wondering how much lower the drain connection would have to be in the wall.
wvphysics is offline   Reply With Quote
Old 07-18-2010, 08:45 AM   #2
Retired Plumbing Cont.
So, the question is: What is the distance to the bottom of your sink? That will determine the height of the waste arm. A new fixture should have a rough-in guide included in the instructions.
rockerjockey is offline   Reply With Quote
Old 07-18-2010, 03:39 PM   #3
Rewards Points: 101
I've downloaded the instructions for a few sinks and they've all only shown how to install the sink to the wall or the legs, doesn't show anything about the trap or connection.
Old 07-19-2010, 03:04 PM   #4
In that case, figure a minimum of 5 inches from the bottom of the laundry sink to the center of the waste arm. That will give you enough room to facilitate p-trap and tail piece installation.
pedestal sink drain stopper not working gernith Plumbing 7 04-18-2008 09:17 PM
The Bioswale, french drain, deck, drainage dilemma (long) seabright_sc Building & Construction 2 01-05-2008 03:37 PM
Drain placement for sink simonb Plumbing 3 09-08-2007 01:08 PM
Drain connection for basement utility sink chickenboo Plumbing 5 09-11-2006 02:30 PM
Drain for an "Outdoor Kitchen" Sink Rich Plumbing 5 08-26-2006 06:48 AM
