Which Heats Water More Efficiently? - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-12-2012, 08:54 PM   #1
fastback4's Avatar
Rewards Points: 51
which heats water more efficiently?
We will need a 50 gal. water heater. I have available a 220 volt source and natural gas. Which of these types heat water the most efficiently? I hate the thought of having to vent a gas heater out to the top of the roof.
fastback4 is offline   Reply With Quote
Old 11-12-2012, 09:38 PM   #2
JOATMON
ddawg16's Avatar
Rewards Points: 1,116
Natural gas will without a doubt be the cheapest way to heat water.
Next option, look into some of the new heat pump water heaters. They basically work just like a standard heat pump....but have issues if your in a cold climate.
Nice thing about gas....it works if there is a power outage.
The Following User Says Thank You to ddawg16 For This Useful Post:
fastback4 (11-13-2012)
Old 11-12-2012, 09:40 PM   #3
joed's Avatar
Rewards Points: 11,988
The question is more efficient or quicker or cheaper to operate.
Electric is nearly 100% efficient. No heat is going out the chimney.
Gas might be quicker and works during a power outage if you don't have one of the high efficiency units that requires a draft blower to be running.
The Following User Says Thank You to joed For This Useful Post:
Solar hot water indatom123 Green Home Improvement 0 12-19-2010 01:01 AM
Cold water is warm - hot water leak under slab? Homerepairguy Plumbing 9 10-13-2010 09:17 PM
Oil fired furnace and hot water heater question steveinpa Plumbing 3 08-10-2010 09:42 AM
How Do I Properly Shock Chlorinate a Water Softner classicflytyer Plumbing 5 07-14-2009 01:15 AM
Low Hot Water Pressure btennant Plumbing 4 12-09-2008 10:31 PM
