All of a sudden with no warning: You have to run the hot water fully opened and cold basically off to take a shower. And the hot water doesn't last no where near as long before it goes COLD. Do I need to replace the element? If so, are they all pretty much standard replacements? Thx. Mike
Could be an element but could also be silt in the water heater.
Elements for water heaters are pretty standard. There are a few odd balls out there for some smaller units. Just pull the bad unit out and take it with you to the local water heater element store.
sounds to me like you have a 2 element electric heater?, if so, it's most likely the bottom element that will need replacing. refilling must be done correctly or you'll fry it right out again!
It is in a manufactured home also if that would matter? How do I test the elements? Are they easy to remove? Never messed with hot water tanks before but sure will be no problem. I know to make sure it fills up before turning the juice on.
Just shut off the electricity, shut off the water, hook up a hose to the drain at the bottom, open the valve, open a hot water faucet to allow air to get in the line and help the draining of the tank. It will take a while to drain. Once it's drained remove the element and take it to the store for the replacement.
Use pipe dope to put the new element in. Reconnect the wire and fill the tank. Turn on the electricity and bled the water lines.
Can't get it to drain. I took the garden hose off and turned the drain on and water does come out. I hook the hose up and it doesn't seem to be draining. Can't be this slow? Electric off, hot water faucet open all the way, open drain valve.....
Need help ASAP!!! Tried opening the pressure relief valve and with it closed. Have 2 hot faucets on. Don't get it. I have a long garden hose running from the drain out the back door and out the yard along a decline and no water has even come out of the end of the hose.
your drain opening likely has calcium/lime buildup. remove hose and open valve. if no water comes out, grab a long screwdriver and dig around.
my friend's did the same thing and that's how i got it to drain.
Tried it again with the hose off and now nothing is coming out. Looks like it may be clogged. I can't seem to get nothing unstuck though. Hard to get a screwdriver to go in cuz it goes in then makes a turn.
O.K., draining finally. I don't think it was clogged, more like vapor locked or something. I opened and closed the relief valve and kinda held it in the middle and could hear it gurgling then when I closed it you could hear the water start gushing out. How long does a 40 gallon tank usually take to drain? It's coming out steady at the end.
LOL, it actually filled up quite quick and heated up quicker than I thought. Still can't believe I had so much trouble draining it. Does that sound about right? It couldve been airlocked? Think i'm gonna do some research on tankless units. This is only a 40 gallon tank and when I start using the whirlpool I don't think it's gonna be able to keep up.
Related Threads
DIY Home Improvement Forum
3.1M posts
319.5K members
Since 2003
