Heating - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-13-2011, 09:26 AM   #1
Heating
Want some help on making the decision about rinnai
Easyjob is offline   Reply With Quote
Old 11-13-2011, 09:49 AM   #2
the Musigician
DangerMouse's Avatar
Hi and welcome to the forum.
Most of our members are DIYers and would have absolutely no idea who/what rinnai is. (On demand water heaters)
Also, this post should be in plumbing section. I'll be happy to move it for you if you wish, you'll get hundreds more views there, and far more opinions.
DM
Old 11-13-2011, 09:53 AM   #3
DM
Thanks I'm a newb
Old 11-13-2011, 09:54 AM   #4
the Musigician
Not a problem, that's why they pay us the big bucks here.
DM
Old 11-13-2011, 10:00 AM   #5
DM
Yes it is the rinnai heating hot water system. Just wanted to know if anyone out there has it, and pros/ cons
Old 11-13-2011, 10:02 AM   #6
the Musigician
From what I've seen here on the forum, opinions vary as to how well they can keep up with demand, but overall, they seem to get good reviews. (Not mentioning any brand names though)
DM
Old 11-13-2011, 10:14 AM   #7
DM
I have lots of lit and pix on the system but no straight talk. Would actually like some kind of input .
Plumber seems to be more a sales person. HD has the water heater but not the combined system.
According to specs its 96% efficiency . Well keep looking thanks
Old 11-13-2011, 10:16 AM   #8
raylo32's Avatar
Rewards Points: 1,254
I am a DIY and I know what Rinnai is! Before replacing my water heater (with a conventional tank type) I looked into getting an on-demand water heater. Things I learned: You need to get a very large one if you have a lot of demand, especially if the water going in is really cold like it can be in winter. Second, they have very powerful gas burners, usually a good bit bigger than for your furnace, so they will be loud and more than likely need a larger gas line from the meter to your manifold. In my case that would have meant a lot of drywall removal. Then there is the venting. Lots of requirements to meet. Best to have an external intake, too, so that monster burner doesn't have to pull a lot of cold dry air into your house.
One option with these is to get a model approved to mount outside, preferably not too far (but at least as far as req by code) from the gas meter. Might need a good bit of plumbing to connect up to it, tho.
Anyway, with all that I decided to get another tank.
raylo32 is offline   Reply With Quote
The Following User Says Thank You to raylo32 For This Useful Post:
DangerMouse (11-13-2011)
Old 11-13-2011, 10:18 AM   #9
the Musigician
See? I told you you'd get quicker answers over here! (Thanks raylo32!)
DM
Old 11-13-2011, 10:50 AM   #10
raylo32's Avatar
Glad to try to help but rereading his subject line I am not sure we addressed the OP's question. He may be asking about applying an on-demand heater for hydronic heating, not potable hot water. Hard to tell w/o more info. I suspect, but don't know for sure, that using one for heat would not need as large a burner and the gas line sizing might be less likely to be an issue. If this is his question the thread should probably be over in HVAC.
Old 11-13-2011, 10:54 AM   #11
the Musigician
Good point. Hard to say either way until/unless he comes back.
DM
Old 11-27-2011, 10:48 AM   #12
I really wasn't sure what to do. I know that my system is not efficient and the cost of heating wouldn't change for the best.
I had my heater winterized like I always do. While talking with the plumber I told him about changing the system to on a combination
on demand heater hot water. I mentioned Rinnai he said it was a good unit but there were just as good and less expensive units
that they would be able to maintain.
He sent me to his plumbing supplier and I had a great education with more literature than needed. He also was willing to send me to
His customer's home so I could ask any questions I need to know.
I chose a less expensive unit with a 95% efficiency rating and energy star hoping to be in time for the $1600.00 rebate.
Thanks for being there. You guys are great
Mini Split for heating in cold climate landev HVAC 9 01-29-2012 10:18 AM
questions about floor heating water tank Hexar HVAC 7 08-10-2011 07:56 PM
Radiant floor heating questions secutanudu HVAC 35 03-08-2010 01:04 PM
Hydrokientix Heating System Not Heating damonl73 HVAC 11 12-18-2009 05:12 PM
Electrical consumption of baseboard heater CowboyAndy Electrical 7 03-24-2008 07:27 PM
