Heated Water Line - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-19-2013, 01:48 PM   #1
n2omichael's Avatar
Rewards Points: 115
Heated Water line
Hi Guys
I have a well about 100ft from my cottage, we just had a full foundation poured for the cottage, so, I will be relocating the water pump, pressure tank, etc. inside the cottage basement from the pump house where it was previously, where we used to draw water directly from the river
The water line from the well will be buried, but, we can only get down about 12" and then you hit solid rock, so, the line needs to be buried.
Can you guys offer opinions and suggestions on which heating system is best? There are several different styles, some heat the whole pipe, some don't, some are built into the pipe, others retrofit, thoughts??
n2omichael is offline   Reply With Quote
Old 07-19-2013, 02:10 PM   #2
Rewards Points: 6,652
Look how they do it in Alaska.. Some areas use a steam coil around the piping, others heat tape, drpendin on how long the run is.
Basically it is pipe within a pipe for the steam or hot water circ coil to keep it from freezing.
BYW, does help to state also where you are in the post, since those of us using mobile devices cannot see it in the profile when you post.
Old 07-19-2013, 02:17 PM   #3
n2omichael's Avatar
Rewards Points: 115
I am located in Ontario,Canada, in the 1000 Islands, about 20mins North of NY State.
Climate is similar to Upstate NY, Michigan or Wisconsin, in other word winters DO get chilly! )-:
Appreciate the input, please keep it coming!
Ps: my length of heated pipe is about 100ft.
Old 07-19-2013, 02:30 PM   #4
n2omichael's Avatar
Rewards Points: 115
I should have mentioned, because its a cottage, we DON'T leave the water on year round. We plan on turning it on while we are there in the winter, then drain the system when we leave, so, the heated line will only be "on" while we are using the cottage.probably for a week or so at a time, and a few weekends if snowmobiling.
Eventually this will be a year round residence, but, I have a few years until retirement yet! )-:
Old 07-19-2013, 02:57 PM   #5
Just next door to my brother, who retired from the Army in Depauville, Ny. Nice area up there.
I know what you are talking about with the bedrock. You almost have to find someone with a drilling machine to break up the stone, so you can get drep enough, or bring in a lot of fill to get the proper depth.
I would try running a under ground rated heat tape alongside it, see how that works first.
Old 07-19-2013, 03:00 PM   #6
DIY staff
Rewards Points: 7,174
Most of the plumbers are working at this time of day---have you asked this question of your well digger?
Because the well has a back flow device---draining the water line will require an air inlet at the well head---so ask them about installing a yard hydrant or hose bib out at the well so you can blow out the line---
A plumber will be along soon---Mike-----
Old 07-19-2013, 03:14 PM   #7
n2omichael's Avatar
Rewards Points: 115
Thanks Guys!
It is a nice area, we are on Wolfe Island, due North of Millen Bay. Was your brother stationed at Fort Drum?
The well was drilled a few years ago by our neighbour, we drilled the well on the property line under the agreement that, when ready, we could hook into it (we split the cost 50/50)
I had planned to install an electric SS solenoid or mechanical valve on the well line,in the well that I could "open" to drain the water line
I have a small Shrader valve on the inlet line of my toilet that I adapted to hook a compressor to so I can open all the taps and blow out all the lines using the compressor, that just leaves the well line.
Thanks Guys!
Old 07-19-2013, 05:17 PM   #8
Yea he was. He decided to go back for his last three years in, so he could make 1st Sgt, before retiring.
Now just spends time working on his car and house, when not doing his job as head Malware advisor for a major software Anti-Virus co.
His wife and son work at the market up the road in Clayton.
I would have to ask him about well co's up there. He does most maint. on his system, so he may not know of a particular co.. I know that where his well is, it is almost next to the house, and they almost have 36-48" of soil, before you hit the Limestone in that part of the yard.
Old 07-19-2013, 05:36 PM   #9
n2omichael's Avatar
Rewards Points: 115
Wow! Sounds like he has done well! Good for him, that is a huge base!
Parts of our lawn have 30-40" of dirt, others have less than 12" of dirt, then, as you mentioned its solid limestone, no wonder the locals call the Island "The Rock" LOL
I am just sniffing around to see the most practical and easiest way to heat my line and to drain it when we leave in the winter, I have done some plumbing before, but, the heat line and well are new to me. At the cottage we have always drawn from the river directly and anywhere else I worked on had "city" water
The Following User Says Thank You to n2omichael For This Useful Post:
gregzoll (07-19-2013)
Old 07-19-2013, 06:05 PM   #10
DIY staff
Electric heat cable is going to be the easiest --I do not know one brand from another or the cost--but I have used a lot of it to heat piping for chocolate---I liked the suggestion of an outer pipe to protect the waterline and electric heat wire.
This should allow you to pull in new heat cable if the existing one fails---add a pull string just in case-----
Old 07-21-2013, 09:12 AM   #11
Rewards Points: 446
What I'd do.
Outer shell of PVC pipe large enough to hold the water line, insulation and self regulating heat tape (rated for this use).
For the water line I'd use a potable water rated PEX tubing. One that specifically states it can withstand freezing without damage. Make sure you use that manufacturer's fittings only, because they also will carry the same freeze resistant rating.
If possible make sure you slope the water line the same as you would a sewer line, back to the well at about 1/8" per foot at least.
As for the schrader valve to blow out the lines. They don't allow for much volume to pass through them. Volume of air is what is going to move water efficiently enough to make sure enough has been expelled to not recollect in low spots in sufficient quantities to cause freeze damage. Maybe a hose bib and make up an air hose connection and get yourself a pressure rated air tank large enough so you can sustain air volume long enough to clear your longest line.
Just some thoughts.
old_squid is offline   Reply With Quote
The Following User Says Thank You to old_squid For This Useful Post:
oh'mike (07-21-2013)
Old 11-01-2013, 01:57 PM   #12
n2omichael's Avatar
Rewards Points: 115
Great idea!
I just had the trench from the cottage to well dug, got Down 3 feet! Which was an added bonus, I am getting some rigid foam now to line the trench with (I did the same with the Big O I used for weepers) to help prevent freezing.
Plan to cut the foam in 1 foot widths and then sandwich the ABS pipe between it, running the water pipe and power lines thru them then back filling with dirt.
I am hoping that getting down 3 feet instead of the 12" I figured I would have should make heating the lines to prevent freezing MUCH easier and cheaper.
Any other thoughts or input would be appreciated!
Thanks guys!
Michael
Old 11-01-2013, 02:25 PM   #13
Rewards Points: 212
Good luck Michael - sounds like you have it under control. I'm originally from Kingston, spent a lot of time (years ago) sailing in the west Wolfe Island/Horseshoe Island area (out of Collins Bay). We just recently moved to our renovated cottage in the Perth/Lanark area.
orange is offline   Reply With Quote
Old 11-01-2013, 07:45 PM   #14
Rewards Points: 152
Where I work here in BC.... when we don't have the depth, we use the pink rigid polystyrene. The old timer tells me that 2" of the insulation equals 1' of fill.
burnt03 is online now   Reply With Quote
Old 11-02-2013, 12:46 PM   #15
n2omichael's Avatar
Rewards Points: 115
Thanks Orange and Burnt, I appreciate the input!!
water heater drip kdange1 Plumbing 6 10-29-2014 05:26 PM
Grossly insufficient water supply to toilet wasting water? mysterylectric Plumbing 8 01-17-2012 11:19 AM
Leaky ball valve at incoming water line Bipin1948 Plumbing 5 10-03-2011 05:21 PM
A blocked water line causing water to loose heat? Snav Plumbing 6 05-07-2010 02:18 PM
Need to run gas line to Tankless Water Heater. anonymouscuban Plumbing 2 04-16-2010 02:56 PM
