Heat Tape WITH Insulation - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-24-2009, 07:53 PM   #1
Heat tape WITH insulation
Hi all,
I have a short piece of PEX plumbing that runs to the toilet under the house and I want to protect it from freezing. I live in Oregon. Here are the specs:
The under side of the joist bays are covered with plywood (it's a very steep slope so you can actually stand under the house. There is some insulation in the joist bays.
My question is this: If I use the heat tape and wrap a piece of pipe insulation (the black stuff with the slit in it), can I also put the regular batt insulation back in the joist bay? Or does that risk overheating? I'm planning on using the self regulating heat tape with built in thermostat.
any tips are helpful. I'm pretty handy but don't have any experience with heat tape. Thanks!
Justin
justinae is offline   Reply With Quote
Old 03-24-2009, 08:37 PM   #2
Safe, Most of the Time!!
brokenknee's Avatar
Originally Posted by justinae View Post
Hi all,
Justin
You shouldn't have to worry about overheating. If it is cold enough for the heat tape to kick on, it is unlikely that the tape will get so hot to cause a problem.
Do yourself a favor and don't buy the cheap stuff from the big box stores. I have used it and it only last four or five years if you are lucky. Unfortunately when you find out it went bad it is usually not a nice warm day when you can fix it. You find out in the middle of the night when you get up for a glass of water or to use the bathroom when the temp is twenty below zero.
I purchased some from my local well guy and that is still going strong.
"Clarity to Agreement" Dennis Prager
Picture/Photo Pitcher/Carafe ------- Where/Someplace Were/Be
brokenknee is offline   Reply With Quote
Old 03-25-2009, 11:50 AM   #3
thanks for the info. i was going to get the Easy Heat which seems solid. Do you remember the brand that went belly up?
Cape Cod Style House Attic/Crawl Space Insulation Help Danielg Insulation 24 05-21-2012 09:20 AM
Need advice on roof heat tape. marchboom Electrical 52 12-04-2011 04:45 PM
Heat Tape on Pipes and Pressure Pump msully8548 Electrical 4 08-28-2008 12:33 AM
Commercial heat tape. rforsha Electrical 3 12-04-2007 08:41 PM
butting insulation between studs-need to tape? yummy mummy Building & Construction 2 02-09-2007 05:21 PM
