Heat Tape - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-23-2011, 12:19 AM   #1
Heat tape
I have heat tape on the water line under my mobile home. Do I need to replace it every few years, or should it be good indefinitely? I would hate my water line and meter to freeze just because the tape wore out. I would rather be proactive, if this is a risk.
Rayma is offline   Reply With Quote
Old 02-23-2011, 04:43 AM   #2
As far as I know, like any wiring or electric cord, it lasts indefinitely. I've had mine on in my crawlspace for about a decade now.
amen2u is offline   Reply With Quote
Old 02-23-2011, 01:39 PM   #3
That is good to know. I was just worried that because it is on continually for about 8 months, that it would "wear out", but I guess other wiring does not.
Old 02-23-2011, 04:21 PM   #4
Rewards Points: 104
After you have unplugged it, or otherwise disconnected the power to it for the season, I would carefully check the entire length of it, inch by inch, for any physical damage, whether from rodents, rubbing on a tight bend, or anything like that. As long as the plug and the cord itself is in good shape, I would consider it "good to go".
Need advice on roof heat tape. marchboom Electrical 52 12-04-2011 03:45 PM
How to stop auxillary heat from coming on defrost cycle and limit auxillary heat use? twilightcall HVAC 34 12-28-2010 06:53 PM
First time taping - Tape has air under it theedudenator Drywall & Plaster 16 04-21-2010 11:13 PM
Heat Pump Blower always on gg_daman HVAC 1 12-16-2009 06:15 AM
Heat Pump Woes Zenica HVAC 50 01-27-2009 07:37 AM
