Old 01-03-2009, 03:30 PM   #1
heat riser
I'm redoing the bathroom in a fairly old apartment building. The bathroom is heated with a riser that is rusty and has been painted many times. Any ideas on how to improve the look of the riser? Thanks.
jgk22 is offline   Reply With Quote
Old 01-04-2009, 08:21 AM   #2
Remodeling Contractor
heat riser
build a nice cabinet around it. Search for post surrounds.. simple kits made to cover basement posts. Sand it down paint with heat resistant paint. Just some ideas.
Old 01-04-2009, 10:55 AM   #3
heat riser
Thanks - I didn't know about the kits. I'll check it out. Be well, Janine
Old 01-04-2009, 11:37 AM   #4
heat riser
One pre built cover: http://www.woodworkingbydesign.net/
Diy had this: http://www.diynetwork.com/diy/hi_bas...447516,00.html
Or try this. http://rrmambo.vox.com/library/post/...ent-stuff.html
Old 01-04-2009, 11:51 AM   #5
heat riser
Thanks!
Getting a House..heatpump or no? DavidsCPU HVAC 10 02-07-2010 11:22 PM
Cracked Heat Exchanger SusanB. HVAC 12 10-14-2008 04:57 PM
Which diagram to use on Lenox Thermostat wiring setup? Heat Pump Lenox techs needed twilightcall HVAC 1 08-13-2008 12:49 PM
Testing FuelMaster 21 Module? Heat Pump no Run. thehotrod11 HVAC 3 12-29-2007 03:11 PM
