Heat From Pipes - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-16-2011, 12:38 AM   #1
Heat From Pipes
This is my first post and I am not sure i'm in the right section but here goes nothing. I live in an apartment which is located halfway below ground level there are heating pipes that are boxed in and there are cut outs here and there throughout covered with mesh for ventilation I guess. I know for a fact that these pipes are not insulated. What is happening is that the heat in the apartment is unbearable even in the coldest months. Is there anything I can do to remedy this? should I have them remove the mesh and close it off? Should the pipes be insulated? I have no idea what to do... any help will be appreciated. Thanks
ohboy114nyc is offline   Reply With Quote
Old 03-16-2011, 12:46 AM   #2
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
are you sure these aren't the heat for your unit and if you turn the thermostat down it will cool off in your apartment?
I would simply start with speaking to the LL about the heat problem.
Old 03-16-2011, 12:49 AM   #3
There is no thermostat in the apt... it is somewhat a "basement" apt so all the pipes from the building run through that floor. I just need something to reduce the heat a little. It's like 90 degrees even in the winter.
Old 03-16-2011, 08:05 AM   #4
Plumb or Die!
Do you have baseboard heaters as well? Or are these heating mains the sole source of heat? If the "holes and mesh" were added as supplimentary heat, I'd just remove the mesh and stuff insulation in the holes. If they're the only heat source that could be trouble. Is your apt. an add on to an older structure and this was the best they could come up with for heat, in lieu of putting a real, controllable system in? I bet the landlord/super is no help.
plumber666 is offline   Reply With Quote
Old 03-16-2011, 10:09 AM   #5
Rewards Points: 1,512
Put adjustable covers on the openings, or drape blankets over them. No need to contact your landlord.
How to stop auxillary heat from coming on defrost cycle and limit auxillary heat use? twilightcall HVAC 34 12-28-2010 06:53 PM
Help with Heat Pump System Wiring AlanScott HVAC 11 10-10-2010 12:19 PM
Comparison and Heat Pump Selection help... ChrisDIY HVAC 7 03-06-2010 08:34 PM
Water Source Heat Pump installation JLMitchell HVAC 6 11-30-2009 03:23 AM
Help..Emergency Heat Running All the Time KatieB HVAC 4 02-25-2009 04:55 AM
